Old 07-10-2015, 10:44 AM   #1
JimmyCriswell
Advice on V-Belts
Can I please get advice on belt routing and size?
1971-1985 Crate Engine with Stock pulleys and short water pump?
If no one can help, what is the most correct way to measure for belt length and what part store is best for belts?
What width belts do chevrolet small blocks use? I have no experience whatsoever with part numbers for belts and what they mean.
JimmyCriswell is offline   Reply With Quote
Old 07-10-2015, 11:31 AM   #2
MARKDTN
Re: Advice on V-Belts
Use stock length belts if you have stock pulleys. I only use Gates brand belts. Available at NAPA, CarQuest, O'Rieleys, and others. They have catalogs that show the proper routing, but it is pretty simple. Is this just an alternator? Power Steering? A/C? A good parts store should be able to help you.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-10-2015, 12:03 PM   #3
Lou Boffa
Lou Boffa's Avatar
x2 on Gates V belts. 13/32 or 10mm work for me. Measuring is tricky if its a custom set up. I use a piece of rope (clothes line size) and a magic marker (parts house has a measuring device) but sometimes wind up returning and getting a smaller or larger size. You want the smallest size that you can get on the pulley when loose so you have plenty of room to tighten the device on the bracket.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 07-10-2015, 04:33 PM   #4
JimmyCriswell
I only have an alternator and the motor did not come out of my year model truck so that is why I am looking to find the length and width of the belts. I guess this will require experimentation.
Old 07-10-2015, 04:42 PM   #5
JimmyCriswell
Old 07-10-2015, 08:34 PM   #6
franken
Belts are sized by length. Take a rope and put it where the belt goes. Mark where the end of the rope meets the the rope some inches away. Measure. Buy belt.
I think by 71 short pumps were gone. You might snap some pics.
Where is the alt mounted? Driver or pass side?
franken is offline   Reply With Quote
Old 07-11-2015, 10:12 AM   #7
Davidf
I believe the stock belt width is 3/8". This means the first number on the belt should be a 3 followed by the length in inches. The first number represents width in 8th's of an inch.
Davidf is offline   Reply With Quote
