Old 07-11-2015, 12:06 PM   #1
68_Step
3 Speed Question
About ready to put the transmission back in today. Had to pull the tail shaft off because we dropped the darn speedo gear in there - opps! Trying to make sure I am in neutral and that the shifter forks are in the right spot. Both ends (front spline and tail shaft) turn freely and independently. Before I put it back in, should I put a drill bit in the alignment holes on the steering column?
68_Step is offline   Reply With Quote
Old 07-11-2015, 02:10 PM   #2
Chucks72Longbed
Chucks72Longbed's Avatar
Re: 3 Speed Question
If both the front and tail shaft spin independent of each other then you're in neutral.
72 Chevy C20 LWB-Just what I always wanted.
Now, just need more time and money!
Chucks72Longbed is offline   Reply With Quote
Old 07-11-2015, 03:05 PM   #3
Jurassic-1
Jurassic-1's Avatar
If you did not screw the linkage in or out there should not be a need to adjust it but you could do it just to be sure.
Jurassic-1 is offline   Reply With Quote
Old 07-11-2015, 03:12 PM   #4
tcrist
If the shifter worked good before it should shift good now. But what the heck, good time for an alignment check anyway. It will not take but a couple extra minutes.
Might be a good time to check the play in the column and replace all of the bushings in the lower unit.
Terry
Soon to be retired and moving to Bristol, TN.
tcrist is offline   Reply With Quote
