07-14-2015, 08:05 PM | #1 |
Having trouble with new door panels
I bought plastic door panels to replace the dinged up rusty metal ones on our truck and they look great but they don't fit in the upper door panel holder like old metal ones did. Has anyone else had trouble going from metal to new plastic door panels? I can't push the panels into the holders far enough. If I pull them out of the door they fit on the panels put not straight. Maybe trimming them? Any suggestions?
07-14-2015, 09:54 PM | #2 |
Re: Having trouble with new door panels
Somebody correct me if I'm wrong and sure they will but the plastic panels are from a 72 and the metal ones are 67-71. the 72 takes a different regulator and lock actuator they are longer on the shaft. Jim
07-14-2015, 10:04 PM | #3 |
I bought the kit from LMC it looks pretty good not going for total correctness on years jist what looks good. But need to make it fit. I know the arm rest were wrong! I think I should have just painted the old ones black!
07-15-2015, 06:30 PM | #4 |
Does this mean none of the metal repros will fit a 72? I was about to buy a set.
07-15-2015, 07:20 PM | #5 | |
I had the same issue. Bought the plastic repro panels and they were way too big to fit into the slot at the top. I used a sanding roll on my dremel to trim them down until they fit. The holes in the bottom didn't match well either, 2 of them were half a hole off on each panel. Once I finally got them installed, they rattle. Horribly. I tried everything, shimming behind them, dynomat, etc. Finally gave up, painted my old metal ones and put them back.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
07-15-2015, 07:21 PM | #6 |
72 takes a different door panel than 67-71. Its a plastic panel with a molded in armrest.
07-15-2015, 07:23 PM | #7 |
07-15-2015, 08:45 PM | #8 |
the kid got a set of those plastic door panels they did need a lil' trimming.
his fit into the upper trim but really loosely not tight like the oe's did. his had extra flashing/molding around the edges that needed triming also had to wallow out a few of the screw holes just a tad as they didnt line up quite rite. the supplied trim washers still covered the holes though. also his dont lay quite flat like the oe's did. he got what he paid for....plastic if ya do trim them just be carefull on how you do it. line up the holes an go from there
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
07-16-2015, 09:10 AM | #9 |
Im a little confused. Are you guys jamming the plastic panels in under the 67-71 style upper trim? I didnt think 72 panels had upper trim.. They mount without. I thought.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
07-16-2015, 09:13 AM | #10 | |
No, we are talking about pre-72. They make aftermarket plastic replacements for the metal door panels used from 67-71. But they don't fit very well and require excessive massaging. I bought them because I had seen a set that looked nice in another truck, and they were inexpensive. I changed my interior from blue to black, and the originals were in poor shape anyways. Turned out to be a bad plan.
07-16-2015, 09:43 AM | #11 |
Oooohhhh. Gotcha!!!!! Yeah, just didnt make sense. Lol. Should have drank my coffee first.
Bummer on those panels. Sure is hard to beat OEM. Good luck to u guys.
