Frame swap?
I am trying to figure out what I want to do with my 71 C10. I found a 76 K5 blazer frame with trans, disc brakes, steering for 500$ that has been cleaned and painted. I know that it is 6" shorter than a SWB C10, but can't find where someone has done the swap. Is it possible with body and radiator mount swaps and extending the rear 6"?
![]() Join Date: Jun 2015
Re: Frame swap?
Possible? Anything is possible with enough time effort and money.
Easy? That's another story. It isn't just the frame length, but the wheel base.
68 C10 SSB 383 12 Charger 6.4L 12 Accord 3.5L (Wife's ride) 05 Ram 1500 5.7L My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545 |
All about them K’s
![]() Join Date: Jun 2014
Re: Frame swap?
The frames drop in different places as well. Anything is possible but it's a lot of work.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Re: Frame swap?
I have done the crossbreeds before where everything does not want to be there or mate up. Yes you can do it, too much work.
I would look for a truck frame (about $300 around here) with discs and power steering. Even if it's a long bed. Cut out 12" and put back together. 1 day operation. Good to go. Everything will then bolt up and be happy. Not so much the other way.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
