Old 07-15-2015, 09:49 PM   #1
jmcfarland
sbc 400 water pump
I'm putting the finishing touches on the engine swap currently and am unsure of which style water pump to go with. If I go with a long pump on the sbc 400 will I run into any issues with the fan shroud clearances, and will I have problems with power steering brackets. I don't know what the 400 had on it stock because I got the block in a trade. Any suggestions and reasons for either a short or long pump are appreciated. Thanks.
P.s. this is in a 67 short stepper.
jmcfarland is offline   Reply With Quote
Old 07-15-2015, 10:35 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: sbc 400 water pump
ALL V-8's in '67 to '72 Chevy/GMC trucks had short pumps. So if you are using all the stock 1967 SBC engine bracketry... use the short water pump.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-16-2015, 07:21 AM   #3
hugger6933
The short pump will go on the 400 small block in case you were worried about that, I have one on my 71 one ton.
hugger6933 is offline   Reply With Quote
Old 07-16-2015, 07:29 AM   #4
MARKDTN
The larger 400 balancer has issues with some power steering setups(both long and short pump). I would stay short pump if it will work. Just trial fit it and see. Other than that, I am not aware of other issues with 400s and any accessories.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
