Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-16-2015, 08:58 PM   #1
BigDan3131
BigDan3131's Avatar
Question In Tank Pumps: Non Stock Tank
So I see these in-tank aftermarket pumps out there but how do you install one in a fuel cell? Do I have it installed when they weld up the tank? Do I need to have some sort of carrier for it to rest in? I don't understand how you put something like this in a tank that electricity goes thru. Is the Aeromotive Phantom the best bet?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 07-17-2015, 02:08 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: In Tank Pumps: Non Stock Tank
I'd just get one of the later model sending unit/carriers from a newer truck, and put a 255 (or other) in-tank pump into it. Guys do it for stock tank swaps.
Then just measure or take them the sender so they can put a provision in the top for the sender to mount (a hole).
Think of it like a fishtank or small fountain pump. Those sit IN the water, and don't short out either.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-17-2015, 05:44 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
you should look at something like this for a cell. http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
you cut a hole in the top and set this in place. it has the pump, pump tray and carrier on it
dwcsr is offline   Reply With Quote
Old 07-17-2015, 06:45 PM   #4
BigDan3131
BigDan3131's Avatar
After digging a little deeper I will go with the Phantom because my cell will be quite large, 28"W X 24"D X 12"H giving me a capacity of 32 gallons with one inch air space. I'm building the truck to be driven more than just around town but down to So. Cal to see friends and relatives.
Old 07-17-2015, 07:03 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Cool. You can do an in tank with any size cell. Some guys use twin-in tanks as well. I'm sure the phantom is a good piece tho. Let us know how it goes.
