Buying R12 Freon on Craigslist
Finally got my R12 system leak tested and ready to recharge it. I am staying with a R12 system.
I found this posting on Craigslist and before I shell out $180 for a partially filled cylinder (gross weight is 18.6 lbs.) I wanted to check with the experts on this forum. Does this sound like a fair deal? (12 oz cans are going for $20-$30 each around here...) Anything specific I should check or be aware of before I purchase? Thanks
"Life is too short to use cheap zip ties" 64 C10 SWB 71 C10 LWB 72 C10 LWB |
Old member
Do you have anyway to weigh it before you buy it to make sure of it's capacity?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Buying R12 Freon on Craigslist
I could bring a digital scale and weigh it but lets assume it does weigh 16.8 lbs. How much would the actual cylinder weigh and how much would be Freon?
Also, any concerns that what is in the tank is still usable? Does time break down the product?
You'll have to see if the guy selling it is a flake. Hope no one recovered something other than r-12 and it is new gas. I have never met anyone on Craigslist that wasn't a weirdo. Buying or selling. Hope its on the up and up. If it is you are getting a good deal. The container doesn't weigh more than 2 lbs.
72 Chevy C20 LWB-Just what I always wanted. Now, just need more time and money! |
Keepin an eye out
Just be aware its not actually legal to buy or sell without an EPA card...I would be leery if you dont have the card as you really dont know who you are dealing with/
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Moderator
![]() Join Date: May 2007
I would only buy it in unused sealed cans. That way you can be sure of what you are getting. I still use it in my 72, factory system takes 4 cans.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Probably a witch's brew of recovered refrigerant.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
my recovery machine uses special tanks with 2 valves on the top...dont know if other brands let you pump recovered freon back into an original tank...a little concerned about the name,havent seen that brand before...make sure its really r-12 and not a substitute like freeze 12
1970 short step c10 leaf spring 454 |
![]() Join Date: Sep 2001
It could be legit. If it were me I'd want to but a refrigerant identifier on it to make sure you're weren't just buying propane.
Nothing wrong with the brand.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
X3. Could just be water and compressed air in there.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
If you check around you can probably find it a lot cheaper. I picked up a case of it ( 12 cans) at the last Decatur swap meet for $35 total. I wouldn't trust buying in a bulk container like that. You don't know what you're getting.
"Negative people always seem to have a problem for every solution" |
