08-04-2015, 06:02 PM | #1 |
Bed Corners
If imitation is the sincerest form of flattery... I would like to do my bed corners like Kabwe's, does anybody know a source for tubing? Looks like 1 5/8", with a pretty sharp bend. I was thinking a muffler shop, not sure if they would have something that diameter. Thanks in advance! Cheers..
1958 Apache short bed |
08-04-2015, 06:19 PM | #2 |
Post Whore
Re: Bed Corners
That is mandrel bent tubing..not what you will find at most muffler shops..it is available on ebay at various suppliers and other sites
08-04-2015, 06:27 PM | #3 |
Re: Bed Corners
Kabwe lives in Southern CA where there is a fab shop on just about every corner that can do mandrel bends. Try and find a shop that does commercial hand rails, or maybe an electrical shop that bends conduit. You might even be able to find some pre-bent, I know wrought iron fence guys buy curves and weld them together.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
08-05-2015, 12:39 AM | #4 |
Re: Bed Corners
I seem to remember Bam saying he bought U bends from Summit and cut them in half. Chances are he'll chime in though.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
08-05-2015, 12:58 AM | #5 |
Re: Bed Corners
I mail order most of the mandrel bends I use.
This is the website for Columbia River Mandrel Bends. They source tube from the US and off-shore and the prices are reasonable. www.mandrel-bends.com/ If you're piecing bends together and welding the joint flush with a tig, then the bends from SPS are better and from all US material, but you'll pay significantly more and the quality is head and shoulders above CRM www.spdexhaust.com/ Another option is some steel supply stores carry bends for metal stairs and wrought iron work. The one here only has one diameter and bend radius, however |
08-05-2015, 12:25 PM | #6 | |
Certified Car Nut
Re: Bed Corners
I used a 16 gauge 1 5/8 u-bend exhaust pipe. I cut in in half and one of them will do both sides of your bed. You can get one here a jegs for 14.99. http://www.jegs.com/i/Patriot+Exhaus...H7015/10002/-1 Last edited by Kabwe; 08-05-2015 at 12:37 PM. |
08-05-2015, 04:17 PM | #7 |
Re: Bed Corners
Man, I like this forum! Thanks all...
08-06-2015, 09:56 PM | #8 |
A320 Pilot/USAF Retired
Re: Bed Corners
JC Whitney has them too.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
08-17-2015, 04:35 PM | #9 |
Re: Bed Corners
