Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-10-2015, 04:15 PM   #1
BigDan3131
BigDan3131's Avatar
Its Being Built
I know most of you were and are against building anything smaller than a 454 but I didn't want massive amounts of torque down low. The dyno sheet is from my machinist and every build they do gets done on the computer and those that also go engine dyno time are within 1 to 3% of the computer dyno.
I am having this 427 [.030 over] built for my use. My truck will see way more freeway time than street time and the cam is ground for mid-range and up power. Cam specs are mild by my standards lift .635/.635 duration at .050 is 233/245 on a 112, its a hydraulic roller cam to add to a longer life. I will be using SS rocker arms from either Norris or Crower since SS can handle the fatigue of being a daily driver better than aluminum [that and I don't trust aluminum rockers no matter how great they are].
The only stock item will be the bare block, its getting a full aftermarket rotating asy all forged and built to run on 91/92 unleaded. I will be using the smaller 265 AFR heads as the 290 heads did make more power but at the added expense of a 1000cfm carb which isn't in the budget [ I bought an 850 DP and single plane intake for $350, both with dyno time only of two hours].
As you can clearly see I'm still making over 500 on torque at 2000rpm.
He's getting me one more dyno sim of the 265 headed engine but with 1.8 rockers instead.
I'm sure your thinking this isn't a true budget engine which it isn't my parts total to around $6500. That's all I'm paying, its a trade build. His machining labor in trade for my paint and body labor.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-11-2015, 12:24 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Its Being Built
Since we don't spend much time doing 500ci LS's, I'm in the "454 and under" corral
Besides, a little nitrous will make up for anything you feel like you didn't get.
Either way, looks like you'll have enough to have fun to say the least.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-11-2015, 06:43 AM   #3
BigDan3131
BigDan3131's Avatar
Re: Its Being Built
Well if I really got serious about racing it I would just switch to E85 and a big turbo
Old 08-13-2015, 05:23 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
Re: Its Being Built
I think that's a great build! That's a daily driver monster! I built my shop truck engine (Pontiac) to pull a horse trailer and then to have fun at my local 1/8-mile drag strip (that's closing anyway). My build cost was just over $4500, doing some trading and scouring swap meets. It runs on 87 octane and backed with a 4L80E, it was getting 20 mpg on the freeway - supported by the brake specific at my cruising RPMs. I also have a 200 hp nitrous system just in case.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-13-2015, 08:12 PM   #5
cableguy0
Re: Its Being Built
I love smaller cubic inch engines making big power. I love nothing more than a guy spanking someone and opening the hood to reveal those small valve covers.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 08-14-2015, 10:21 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Its Being Built
^^^ I agree 125%
It's still why I fiddle with SBC's to this day.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
