Wiring Harness for my 54 Chevy Truck
I have been told that the EZ wiring Harness is more user friendly than some of the others. If so which one do I want to buy? I notice there is a few different one's EZ mini, Ez deluxe, EZ 21 circuit? I have all the switches already and ignition and my key will be in the dash. I sold my painless key in the column because I was told painless was not as easy as some of the others like EZ wire. I'm ready to buy just need a little help to get the right one. This is my first street rod so I want it to be as easy as possible.
Thanks, |
Re: Wiring Harness for my 54 Chevy Truck
I used EZ wire on mine, 21 circuit, but I have ac, will be towing and wanted the extra circuits. If you truck is bare bones then a smaller one will do. Instructions I thought were good, I had a couple of questions and got the owner when I called. He answered both on the spot. Wires are labeled and the ignition and lighting are terminated. The rest are not terminated, but not a big deal because I found I had to shorten or lengthen just about every wire to get the correct length. You can look at my build thread, I show a lot of detail and commentary, planning is key and finishing up each part rather than jumping around makes it go easier. I did the back first, they front, then engine and dash last. I added headlight relays, courtesy lights with door switches, alarm, and other stuff that is not in the kit using circuits that I would not be using like power windows and power door locks. I got a good deal on the basic kit online and spent about $250 more for additional connectors, fusible link, shrink wrap, wire loom, relays, ground wire and additional switches I needed.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#3 | |
Thanks |
