Old 08-13-2015, 05:19 PM   #1
tigerburns
Active Member
tigerburns's Avatar
Best Conversions and Modifications
Ok folks...
I am a longtime Chevy truck lover, a short-time C10 owner , and a first-time poster to this forum.
I have read lots great threads about possible conversions/modifications/upgrades that can or should be done to your truck. What I want to know is which ones do you consider to be the best? What modification have you done that you wish you had done sooner? For you guys who work on one build after another, what modification(s) do you consider “have-to”? What upgrade offers the best “bang for the buck”? What is the low hanging fruit that should be plucked first?
I currently have a ’65 short fleet that has been lowered and had a 350 conversion. It is an old restoration that needs some updating both aesthetically and mechanically. The body and chassis are in very good shape with very little rust and no rot. The truck has also been recently rewired.
I have to keep reminding myself that this is meant to be a marathon and not a sprint, but I can’t wait to get started. So what should I start with?
tigerburns is offline   Reply With Quote
Old 08-13-2015, 05:30 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Best Conversions and Modifications
Welcome! For me, it's front disc brakes and a three- or four-point driver restraint/seat belt system.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-13-2015, 05:37 PM   #3
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Start with ALL the Mechanical 1st. Get the engine running good and make sure its worthy of a good tune up. Check the radiator fluid and make sure there's no rust in the system and preferably flush the system out. Check your fuel line and the tank to make sure there's not a bunch of rust and crap in there. Then move to the tranny... weather its an auto or manual.. check the fluid levels and change them if needed and make sure it shifts fine. Then move to the rear axle and inspect it and make sure the gear oil is up to level and not full of water. I'd also check the front suspension(upper lower ball joints ect) for wear and tear and grease them. Then check your brake master cylinder and make sure it will hold foot pressure and the fluid is to the top. Then drive it! See how she runs...do a burnout or two and go from there. So here's a sum up:
1st. Make sure its mechanically sound.
2nd. Make sure you have a good drive train.
3rd. Make sure your electrical is all working properly.
If all that is fine....then I would move to the body. Unless I was doing a frame off restoration then I would tear it down and put a crate engine in it. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 08-13-2015, 05:43 PM   #4
pwrbrkpadguy
pwrbrkpadguy's Avatar
Front sway bar, HEI dizzy, volt meter upgrade.
pwrbrkpadguy is offline   Reply With Quote
Old 08-13-2015, 05:55 PM   #5
tigerburns
Active Member
tigerburns's Avatar
Thanks!
Yeah, I need to do the belts. That's the first question the wife asked. HA!
Good advice. The engine IS a new 350 with less than 1000 miles on it. Have docs to prove it.
Why the HEI distributor? ...just curious...
Old 08-13-2015, 05:57 PM   #6
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
HEI is better than points and usually lasts longer. Also looks cooler.
Old 08-13-2015, 06:09 PM   #7
joe dirt
joe dirt's Avatar
id say the first thing that needs to be done is post up some pictures so we can see
1961 c10 longbed - gone
1964 c10 swb
joe dirt is offline   Reply With Quote
Old 08-13-2015, 06:29 PM   #8
siggyfreud
siggyfreud's Avatar
I'm going to guess front disc brakes, which I have done, but haven't driven on yet . As far as mods I have done and driven . . . fuel injection + overdrive. Really enjoyed the benefits of going from a carb to multiport fuel injection, combined with getting an overdrive gear (Th-350 to 700r4).
siggyfreud is offline   Reply With Quote
Old 08-13-2015, 07:17 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
/ LS motor
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-13-2015, 09:32 PM   #10
tigerburns
Active Member
tigerburns's Avatar
You're right...here she is.
Old 08-13-2015, 10:01 PM   #11
MikeN
MikeN's Avatar
That's easy...power steering.
MikeN is offline   Reply With Quote
Old 08-13-2015, 10:08 PM   #12
Jim53066
Jim53066's Avatar
Yup, Easy one.
Power brakes,
power steering,
then drive the heck out of it as is.
Jim
Jim53066 is offline   Reply With Quote
Old 08-13-2015, 11:49 PM   #13
markeb01
Senior Enthusiast
markeb01's Avatar
Power steering and power disc brakes, at least on the front. HEI ignition is simple and easy. I'd stop there and see what else needs to be done.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 08-14-2015, 12:43 AM   #14
Captainfab
60-66 Nut
I agree....nice looking truck and welcome to the forum
Old 08-14-2015, 06:31 AM   #15
PGSigns
PGSigns's Avatar
Power front disc brakes, power steering and seat belts. Nice truck.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-14-2015, 07:35 AM   #16
tigerburns
Active Member
tigerburns's Avatar
Originally Posted by Jim53066 View Post
Yup, Easy one.
Power brakes,
power steering,
Jimmy
Hmmm...I seem to be sensing a theme. Thanks guys for the advice and compliments.
Old 08-14-2015, 08:47 AM   #17
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
That looks just like mine!!!! maybe they are distant relatives???
I have to agree with these fellas, power dics brakes, power steering to start.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-14-2015, 09:19 AM   #18
cooperhw
cooperhw's Avatar
Jimmy
^^^What Jimmy said^^^
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
builds, conversion, modification, restoration, upgrade
