Old 08-17-2015, 10:09 PM   #1
nab407
Can you identify these wires/circuits?
Hey guys,
I've torn out all of the wiring in my truck, bought the shop manual, and am currently in the process of identifying, cleaning, rerouting, and looming all of my wiring. However, and as to be expected, I have run into some wiring that I cannot identify even with the shop manual diagrams. Please help!
My truck is a 1983 Chevy K10, 4x4, Auto, w/6.2L Diesel
1) Out of slot #18 on the instrument panel connector, exits two pink wires. One leads to nowhere (the one in question) and the other is circuit 30 and leads to the main firewall connector. Circuit 30 is labeled "Fuel Gauge to Tank Unit"***
2) Again, from the instrument panel connector, exits a pink wire from slot #7. It currently leads nowhere. I don't know what circuit it is.
3) From the seatbelt buzzer on the main fusebox exits a black and white wire. Goes nowhere. Circuit unknown.
4) Three wires that were jerry-rigged to go to my cigarette lighter by the previous owner. Two orange, one white. I traced them back to their source and found that one orange goes to the horn relay, the other orange goes to the headlight on/off switch, and the white goes to the headlight on/off switch, as well. Circuits unknown.
5) Black wire sourced to factory splice with one end going to seatbelt buzzer and the other going to ground. Circuit unknown.
6) Gray wire going to "Instrument" panel fuse on main fusebox with a 5-amp fuse. Circuit 8A in diagram, 'Fused No.44 Circuit' on circuit identification sheet.
7) Yellow wire traced back to 'Radio' 15-amp fuse on main fusebox. I'm pretty confident this is the radio power feed, but I just wanted to double check.
Any help would be GREATLY appreciated and I'll give everyone $1000!
*Disclaimer: I will not give anyone $1000.
nab407 is offline   Reply With Quote
Old 08-17-2015, 10:24 PM   #2
nab407
Re: Can you identify these wires/circuits?
Old 08-17-2015, 10:25 PM   #3
nab407
Old 08-18-2015, 10:48 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
1 and 2.. gas gauge sender wire,some are jumper factory wired (7)small to (18)big gas gauge.
3.key in or Belt buzzer,i removed it all
4.did it have an alarm before? horn beep/light flash ?
6.yellow is radio,should have grey and black for it too
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-18-2015, 01:20 PM   #5
nab407
Thanks for the help. For 1 and 2, do I only need to hook one of them up to the sender then or should I splice them both together then run them to the sender?
3. I'm trying to bring the truck back to stock (as annoying as the buzzer can be), so does this wire just run to the seatbelt retractor?
4. No alarm that I know of...
6. Where do the grey and black wires lead?
Old 08-18-2015, 11:59 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
For the sender use the proper hole spot. For the size you have.
I'll check but the buzzer is seperate in mine.
Grey is for the radio light, black is ground for radio.
John
Old 08-19-2015, 07:17 PM   #7
nab407
Ok, so the black wire runs from the ground/seatbelt buzzer ground to the radio, as does the yellow wire, and the gray wire?
Old 08-20-2015, 09:46 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
here is stock speaker plugs into an adapter,and radio
you can see the power yellow in the black plug,but there is another speaker yellow
later with memory and headlight dimming ,they have the orange/brown wired plug
John
Old 08-20-2015, 03:49 PM   #9
nab407
Those pics and diagram were very helpful! I think I've almost got 'er figured out...
circuit, electrical, wire, wiring
