Old 09-09-2003, 03:06 PM   #1
sactoC10
71 DELUX
sactoC10's Avatar
control arm (upper?) shims
So I am scraping and cleaning and scraping and cleaning my 71 these days and occasionally a peculiar item shows up that looks as if it needs to go somewhere.
Last week I found a shim, sort of a square U shaped deal, not sure which side it came from. Was this probably a control arm shim...and might it (and others) be the reason why my truck was only rubbing on one side when lowered last week?
What's the deal with these. Are they known to come loose and fall out over time?
sactoC10 is offline   Reply With Quote
Old 09-09-2003, 05:39 PM   #2
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
could be.... I was about to reply for you to check your shims in your other post.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 09-09-2003, 10:29 PM   #3
CoryM
Well one thing is for sure, its time for an alignment anyhow. Sounds like a camber shim. They *can* come out, but when one comes out usually all of them do. More likely someone just dropped it. Another thing it could be is a fender shim for aligning body panels. Did you remover the cross shaft (the one in the A-Arm) when you lowered the truck?
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada
http://www.geocities.com/chevroletc1070
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
Old 09-10-2003, 09:55 AM   #4
kxmotox247
kxmotox247's Avatar
Body shim at the fender to cowl area?
kxmotox247 is offline   Reply With Quote
Old 09-10-2003, 10:09 AM   #5
sactoC10
71 DELUX
sactoC10's Avatar
found them !!!
...and man, there was a ****load of them on the driver side!
No kidding, there were two washers, and SEVEN (7) shims on the bolt to the front of the upper arm. All different shapes, sizes and thicknesses. On the rear bolt there were two washers and three thick shims.
I removed one from the rear bolt and four from the front, leaving the three thicker ones and when I dropped the truck, all was well. Each side looked pretty darn equal, which was not the case before. This was a rewarding bit of work in the garage.
The camber shims did look more like a square "Y" than the other shim I recently found. Still not sure where it cam from...maybe more details about the cross shaft CoryM? Fender shims?
No more tire rub!
Thanks much for the input.
Old 09-10-2003, 10:59 AM   #6
jamis
F.A.S.T. president
jamis's Avatar
I never have extra parts left over
I do always have a pile of WEIGHT REDUCTION PARTS mostly composed of bolts, washers, pins, springs etc. Sometimes its fun to sneak it into my buddys garage and throw it in his pile and let him figure out what it is..... lol.....drives him crazy....he's still tring to figure out where that extra bearing goes in his diff....lol
jamis is offline   Reply With Quote
Old 09-10-2003, 11:15 AM   #7
CoryM
If you like your tires take it to an alignment shop. The shims are probably there for a reason. You cannot just pull shim out like that. Usually the camber shims have little tabs on top. THe shim you found the other day is probably a little larger and from a body panel somewhere. You shim the fenders to make them line up with the cab.
CoryM
Old 09-10-2003, 11:25 AM   #8
sactoC10
71 DELUX
sactoC10's Avatar
Well, if you saw how badly the driver side tire was sticking out on top, as opposed to the LHS, I think you'd agree that removing a few of them was not a bad idea. I didn't remove all of them, not even half!
Since the person I got the truck from never paid much attention to any details or put much care into it, I know he did not get it aligned in the last five years. All of the work that was done to it was done by his dad.
This truck had heavy duty helper leaf springs and used to have a camper shell (the reason my bed looks so great) and occasionally towed a small boat in the 70's and early 80's. The auxiliary tanks were used too. It did some work, but it was well cared for.
Now that the HUGE rear bumper, auxiliary tanks, helper leafs, stock tires/wheels and suspension are no longer in place, I am certain that the abundance of shims are not necessary on this one side that cleary stuck out more that the other.
I'll keep you posted once the alignment is done.
Old 09-10-2003, 11:43 AM   #9
68LSS1
68LSS1's Avatar
Dang near fell off my chair. That's funny.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 09-10-2003, 09:24 PM   #10
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Does anyone know of a book or guide on HOW to align a front end yourself??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 09-11-2003, 01:19 AM   #11
CoryM
Phantom dually, Its pretty hard to do an alignment at home on a street driver car. However, there are a few pretty neat systems guys have figured out for their (low dollar) racecars. Start looking at roadrace and oval track books. With race tires you can adjust, do a few laps, then come in and adjust more. ON a street car its usually worth the $30-50 to get it done. BTW not all alignments are the same. If you drive hard look for the guys who do the local racers alignments. They will know how to set the car up for better handling while still maintaining good tire wear.
CoryM
