Old 09-01-2015, 02:43 AM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
New Exhaust setup on my '66
I'm now running Hedmann Hustler LS headers in the 66. It was time to fab up a new exhaust, and the choice was a dual 2.5" system with an Hpipe and some new "mufflers". I got some mandrel bends from Columbia Mandrel Bends, some T's and Dynomax Race Bullets from Summit, and a few misc pieces and clamps from the bin and parts store.
Used a jig I made so I could split 180*s in half for S-bends on the chop saw with a diamond wheel. Then started from the collector and worked my way back measuring and laying out each bend. I wanted a symetrical setup which was annoying because the headers have slightly different outputs.
Once we got to the h-pipe I made a few mental decisions on where I wanted to weld vs clamp for ease of assembly and access, then tac'd up those areas, and clamped the others. After that, we hung the mufflers on the existing hangers from my old setup, then build the pipes to mate them up to the H-pipe.
Happy with fit up, we dropped the whole thing and finish welded it. After cooling, we measured corners and widths for square. Our total amount off of square was barely 1/4" (industry standard is .60 compared to my ~.25)
The actual dump/tip needs to be made still, as its a bit of a strange egress to my side-exit holes, and we are debating 2-3 different styles of tip and exit...but haven't settled on one yet.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-01-2015, 08:55 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: New Exhaust setup on my '66
nice job Br3w!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-02-2015, 04:38 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thanks Clyde. For a fun comparison, look at the "built in 20 minutes because my tuner wouldn't run it open headers" exhaust that we ran for WAY longer than was ever intended. Fluxcore on 120v and miter-cuts sure don't add up to a pretty piece! SOOOOO glad I built the new setup.
Old 09-02-2015, 05:02 PM   #4
LowLifeS10
LowLifeS10's Avatar
I like the old one better nah, the new setup looks really nice
GMC C15 -68 project: http://67-72chevytrucks.com/vboard/s...d.php?t=526059
Front/back Porterbuilt dropmember, Accuair, LS1/4L60e
Chevrolet C20 -72 C20 to K10/20 conversion, LS power.
LowLifeS10 is offline   Reply With Quote
Old 09-02-2015, 06:41 PM   #5
siggyfreud
siggyfreud's Avatar
Looks awesome! Way more pro than my DIY system . Welds are better too.
siggyfreud is offline   Reply With Quote
Old 09-03-2015, 09:25 AM   #6
Clyde65
Clyde65's Avatar
a man has to do what a man has to do!
Clyde65
Rebuild of Clyde
support our troops!
Old 09-04-2015, 12:06 AM   #7
crazy longhorn
Fabricate till you "puke"
Nice fit ! Do we hear a sound clip coming? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-05-2015, 12:20 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Maaaaaaayyyyybe.
Yea I'll have a clip up soon. I've still got Parts 3 and 4 of the "LSx C10 Mods" video's I've been doing this summer to upload first tho....otherwise I'll be jumping the shark and spoiling all the fun of the buildup to that point.
Old 09-07-2015, 01:54 AM   #9
crazy longhorn
I will bet , that you will find a big difference in flow/performance, from the last set Mine was done in the ex shop (my hands on). From the long tube headers, to the muffs, was a straight shot? 50's flows/H pipe just behind the trans cross member. The tails are crush bent, but easy on the angles. When I went with the 5.3, I opted for Hooker street rod shorties & went mandrel bent downs. I see that you used a couple band clamps...I did that also, but just a mention....I like to runs a 1/2 -3 4" weld on the pipes 2 sides before the clamp goes on? This just helps keeps things in place. Let us hear it....Longhorn
Old 09-07-2015, 02:16 AM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I considered doing that with the clamp to "center" it. If I had a TIG I'd but a fine ripple on there, but with my MIG I'd end up with with too wide of a weld and casing a problem. I'm actually thinking about replacing that with a v-band because that area supports a little more weight than I planned on, but works well so far.
