Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-01-2015, 11:38 AM   #1
shortbed70
shortbed70's Avatar
3000 700r4 convertor
I bit the bullet and purchased a 3-3200 10" lockup convertor for my 700r4 in my 65 Chevy. I'm curious as to your opinion on stock in radiator coolers vs external coolers and piggybacking them... Also refresh my memory on what trans lines are hot and cold (top and bottom)
I'm hoping to help the truck wake up from idle and to be able to turn my idle down a bit...
Previous 1/8 th mile passes 9.02-9.08 @ 76ish mph with 12" 2400 conv leavin just off idle!
3.73, 27" tire, shift at 5800 going through hitting rev limiter before third shift at stripe..
This is a street cruiser so didn't want anything to drastic..
What are your opinions?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 09-01-2015, 12:57 PM   #2
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Re: 3000 700r4 convertor
kind of a crappy pic, but you get the idea
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 09-01-2015, 01:27 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I prefer to run external only with a seperate fan cooler and control for it. If you don't want to run a larger fan cooled unit, then piggyback them as shown.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-01-2015, 01:30 PM   #4
shortbed70
shortbed70's Avatar
Think I've got mine backwards...
Troy
Big Red Dog build
Old 09-02-2015, 11:52 AM   #5
Domer
Domer's Avatar
I have a 3 core aluminum radiator with dual electric fans and shroud, i ran the biggest trans cooler i could get with out a fan and just by passed the radiator. If you look down in the radiator, there is not much volume of atf to be able to be cooled. And if it leaks, there goes your trans..
Project Roxy...
Shes Bad, Low, and Blown...
http://67-72chevytrucks.com/vboard/s...d.php?t=673333
Domer is offline   Reply With Quote
