Old 09-03-2015, 10:31 AM   #1
Wizit247
Wizit247's Avatar
Help identifying 12 bolt!
So from any of my searches my stamp on my 12 bolt doesnt have as many numbers as it should. can someone more knowledgeable than me decode this? or point me in the right direction.
This is stamped on the passenger axle tube just like it should be. There was only one number cast into the center section. it was tho lower right if seen from the rear. cant remember the number. it started with a G and ended with 55.
Much appreciated!
-Wizit
Over the top, billet infused, ground up 60 GMC build http://6772chevytrucks.com/vboard/showthread.php?t=809901
Wizit247 is offline   Reply With Quote
Old 09-03-2015, 12:02 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Help identifying 12 bolt!
What are you trying to find out?
If it is limited slip and what ratio?
After 40 years... anything could be in there. Unless you're the original owner of the truck. I'd just pull the cover...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-03-2015, 12:18 PM   #3
Wizit247
Wizit247's Avatar
Gary
Mostly just what to tell the kid behind the parts counter what vehicle i need parts for.
Old 09-03-2015, 12:38 PM   #4
Clavo106
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
Clavo106 is offline   Reply With Quote
Old 09-03-2015, 12:55 PM   #5
Wizit247
Wizit247's Avatar
Originally Posted by Clavo106 View Post
thanks..
i guess ill keep searching. my axle doesn't match anything in that thread or the countless others ive been through
Old 09-03-2015, 01:00 PM   #6
GASoline71
GASoline71's Avatar
If it's a truck 12 bolt... the early ones had 16 spline axles and then the later ones had 30 spline axles. 1971 was when they were widened a tad.
What parts are you looking for?
Gary
Old 09-03-2015, 01:08 PM   #7
Wizit247
Wizit247's Avatar
Gary
Mostly brakes. potentially diff rebuild.
The diff cover shape is that of a truck axle.
Also, it is 6 lug if that helps any.
Old 09-03-2015, 01:46 PM   #8
67 chevelle
67 chevelle's Avatar
what year truck , if its a 68 , ha is a 3.73 open axil , the majority had these
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 09-03-2015, 02:08 PM   #9
Wizit247
Wizit247's Avatar
unfortunately its not from the truck originally. It came with a frame that I bought.
Old 09-04-2015, 04:07 PM   #10
Mike C
Mike C's Avatar
Just take the cover off. Looks like you are cleaning and painting the outside (lipstick on a pig?). So go ahead and clean out the inside and add to new seals and fluid including limited slip additive if needed.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-04-2015, 04:18 PM   #11
Wizit247
Wizit247's Avatar
As previously stated its not the gearing that Im worried about whatsoever. I need an application to give when buying parts.
If I walk into the parts store and tell them I need brakes for a 12 bolt I will get a blank stare.
Old 09-05-2015, 06:00 PM   #12
jdw
Any luck? Here's a bump for you.
jdw is offline   Reply With Quote
Old 09-07-2015, 05:10 PM   #13
Redline novdog
Redline novdog's Avatar
The main difference is axle length and 5/6 lug. As stated above splines. If your painting it. take the time pull the cover/measure the axles and housing.You'll know for sure what you have.
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 09-07-2015, 08:57 PM   #14
carguygregg
A picture of the complete rear end might help narrow down the year. If it's a 2wd truck, They had 2 different track bar mount designs depending on yearly or late. All of our trucks used the 11"x2" brake shoes. 60-63 were different from the 64-72, but that was it. I understand the frustration with going to get parts at the parts store anymore....If they can't look it up in the computer, they are lost! I worked behind the parts store counter when you looked things up in books!
carguygregg is offline   Reply With Quote
Old 09-07-2015, 10:12 PM   #15
Mike C
Mike C's Avatar
Ring gear will have a date on it if it's original. This is a coil spring truck, correct? They parts should all be the same '66-'72. '63-'65 MAY have some internal differences, I know on the passenger car they first year setup shim pack is different. Can't be any other range than that if a factory coil spring setup.
44 Willys MB
52 M38A1
64 Corvette Coupe
