Old 09-05-2015, 09:55 PM   #1
ihatericeburners
ihatericeburners's Avatar
New Cam/heads and it wont start. Help!
Started with a goodwrench 350 and added a comp cams xe262 and stock vortec heads, with edelbrock manifold. I have an edelbrock 1406 carb with a rebuilt HEI, I did myself. I replaced the timing set. I have verified TDC with a piston stop and marked my balancer. I installed new hydraulic lifters from comp cams.
While attempting to first attempt to start the engine, I got a small backfire through the carb. The engine sounds like it wants to run but only starts to sputter slightly. I checked the orientation of my rotor, pointing to the number 1 plug on the cap. I rechecked that TDC matched the intake valve closing and by feeling the blowing of air out the plug hole. The valves were lashed using the jiggle up and down method and turning crank 90 degrees at a time. I primed the engine with the tool with the collar to get oil flow the galleries. She had plenty of oil pressure. Filled the bowls with fuel, and filled the line from the mechanical pump to the carb. There is fuel into the carb. Firing order has been triple checked. My battery has been verified with a load test and I have 12 volts to the Hei. I have the initial timing set to 10 degrees BTDC. Timing was verified by a timing light while engine was cranking. Therefore I must have spark to the plugs if the light was picking up the signal.
I am just stumped on what my issue is. I am open to any ideas on what to check next and possible solutions.
Thanks in advance!
ihatericeburners is offline   Reply With Quote
Old 09-05-2015, 10:06 PM   #2
leftybass209
leftybass209's Avatar
Re: New Cam/heads and it wont start. Help!
Did you check that the cam was installed correctly? You can be exactly dead on with tdc, but if the cam and timing set wasn't in alignment, your exact symptoms will occur. If that is spot on and you know for sure it is, advance or retard your distributor. You've got nothing to lose because it already won't fire.
leftybass209 is offline   Reply With Quote
Old 09-05-2015, 10:16 PM   #3
Thorkle Rod
You didn't say anything about if your plugs are actually putting out a good spark. I would suspect the coil or electronics of the HEI. I have received bad ones that were brand new and made my life very frustrating. Good luck
Thorkle Rod is offline   Reply With Quote
Old 09-05-2015, 10:18 PM   #4
firedemon
sounds like too far advanced if its getting 10 degrees with only cranking engine when it starts it will be 50 degrees or better try playing with distributor
firedemon is offline   Reply With Quote
Old 09-05-2015, 10:25 PM   #5
ihatericeburners
I installed the cam and timing set "dot to dot" Then I turned the engine over to get both at 12 o'clock. But then I had something tell me that timing was off when I was doing my valve lash. I verified TDC and found the timing mark on my balancer didn't match. I have turned the engine over many times now.
I tried playing with the timing too. Going from 0 to 20 degrees. I also have a flat tappet cam and don't want to run the risk of wiping the lube off my cam.
Thanks! I feel like its always best to talk these kind of things out.
Old 09-05-2015, 10:30 PM   #6
agawam
If you put in a new timing set and lined up the timing marks so that they were crank gear up 12 oclock and cam gear a 6 oclock the engine will be set to fire no.6, with both time marks at 12 oclock then it fires no 1 if when you try to start and get a back fire you could be 180 off
agawam is offline   Reply With Quote
Old 09-05-2015, 11:08 PM   #7
88Stanger
88Stanger's Avatar
I am sure you know that the piston will come up twice to the top, once for compression and once for exhaust. I have done the finger in the hole and waited for poff on the finger only to discover later that it was on the exhaust lift and we were 180 degrees out on timing, just trying to help. sometimes simple things can get us.
88Stanger is offline   Reply With Quote
Old 09-05-2015, 11:15 PM   #8
ihatericeburners
This makes sense. I will have to investigate. I used the blow off method when the valve cover was on. So I have some doubt.
Old 09-05-2015, 11:58 PM   #9
ihatericeburners
I verified 12 volts to the hei from the ignition. I pulled the distributor to start ruling stuff out. Anyone know of a goodwrite up testing tit with a multimeter? I found a few. But I NEED one simple for me to understand it better.
Old 09-06-2015, 01:36 AM   #10
ihatericeburners
I am re- revivifying TDC. Has anyone used a spark plug piston stop tool and got a incorrect reading? maybe upward travel of the exhaust stroke?
Old 09-06-2015, 07:34 AM   #11
Daman
I'm going to go with rockers may be too tight. Back them all off 1/4 turn. Then try restarting.
Daman is offline   Reply With Quote
Old 09-06-2015, 07:39 AM   #12
Kennuck
Kennuck's Avatar
x2
A finger in the plug hole is not a good way to determine TDC on compression stroke. You're likely 180 out, backfire through carb is classic symptom 180 out. Give it a try its easy to do and will likely fix your problem.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 09-06-2015, 09:49 AM   #13
cooperhw
cooperhw's Avatar
Sounds like 180* out to me. Pull the dist. bring up to tdc with your finger in hole it will push compression out. On exhaust stroke at tdc the exhaust valve is fully open. look inside the motor with a flash light and turn the oil pump so the dist. will drop where the rotor points towards #1 cylinder and the dist. has adjustment forwards and backwards.
Not saying it's perfect, just how I do it.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 09-11-2015, 10:11 PM   #14
Thorkle Rod
Just curious if you have figured this out yet?
Old 09-12-2015, 12:42 AM   #15
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I was thinking the exact same thing.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-12-2015, 03:52 AM   #16
DWilbur
I had the same problem and install the wires on the dissy backwards to the rotation. rewired it and fired right up.
DWilbur is offline   Reply With Quote
Old 09-22-2015, 08:28 PM   #17
ihatericeburners
Sadly I still have my problem. I tried the suggestions above and still nothing. Im at the point to just buy a new distributor and carb.
Old 09-22-2015, 08:40 PM   #18
NC_John
NC_John's Avatar
The comp cam timing hieroglyphics for advanced, 0 degrees and retarded might have you messed up. I screwed up mine when I installed the timing set and it drove me crazy trying to figure out why it wouldn't fire. Finally dropped the pan and pulled the timing cover and sure enough, I had buggered it up.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 09-22-2015, 09:25 PM   #19
CC69Rat
CC69Rat's Avatar
Just thinking out loud - starting from TDC
If you initially installed the cam and crank gears dot to dot then rotated around to get them both at 12 oclock, wouldn't #6 would be on the compression stroke at that point (?)
If the dist is dropped in pointing at #1 it would be way out. (Retarded / 180 out) as others have stated.
Maybe.. pull the dist back up and turn your oil pump gear so the dist will drop and the rotor points at #6 on the intake stroke. Just curious if it will fire.
I'm not following why Comp would suggest 6/12 oclock on the installation then rotate to 12/12 ? If I'm at TDC at 6/12 and rotate it then lining the dist up at #1 the traditional way kinda goes away .. the crank would rotate a full rotation for 1/2 the cam rotation.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 09-22-2015, 10:49 PM   #20
67 chevelle
67 chevelle's Avatar
my vote also , assuming engine was put together correctly
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 09-25-2015, 01:51 PM   #21
cg285
I installed the cam and timing set "dot to dot" Then I turned the engine over to get both at 12 o'clock. But then I had something tell me that timing was off when I was doing my valve lash. I verified TDC and found the timing mark on my balancer didn't match. .
dot to dot or dot to zero
cg285 is offline   Reply With Quote
Old 09-25-2015, 01:53 PM   #22
cg285
probably why the balancer didn't line up - wrong dots
Old 10-05-2015, 06:41 PM   #23
ihatericeburners
The good news is she's alive!
the bad news is I still have issues. I belive they are with timing. I have been getting a backfire through the carb when I start it and I have to press the pedal to the floor to get it to start. So I have more work to do still.
thanks!
Old 10-05-2015, 06:53 PM   #24
ihatericeburners
[IMG][/IMG]
Old 10-06-2015, 07:34 AM   #25
PGSigns
PGSigns's Avatar
Recheck the firing order to ensure they are all good. Now to verify a timing mark with a stop you insert the stop and turn the crank by hand till it touches. Put a mark on the balancer and rotate it back around till it touches. Put another mark. The spot in the middle is zero. Use this mark to align a timing tape. Then use the timing tape to see exactly what the timing is doing. That will help you get the initial timing correct and tell what the hei is doing as the rpm goes up. A timing curve that is out in left field will cause all kinds of issues. Now we need to talk about fuel pressure. Much more than about 4 psi at idle and 5 while running will make it unhappy.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
