09-06-2015, 06:49 PM | #1 |
switched eddy 750 to holley 750
I switched my eddy 750 to holley 750 and found I'm getting more power and better fuel economy. Still think I need lighter vacuum spring tho. Has anyone else noticed the difference in these carburetors ? The eddy was just to sluggish. Here's what its in
09-06-2015, 07:07 PM | #2 |
Moderator
Re: switched eddy 750 to holley 750
Big block? An Edelbrock 750 is too big for a small block. I run a 1405 600CFM Edelbrock on my my 71 350.
09-06-2015, 07:16 PM | #3 |
its on a 383 stroker, 86 k20. jasper engines class 2, I dont think its too big ...got lots more power now .
09-06-2015, 07:16 PM | #4 |
the only time I saw a 750 Edelbrock work on a small block was with a underhood blower. Jim
09-06-2015, 07:20 PM | #5 |
Moderator
Any carb can work fantastic...or any carb can work like crap. Doesn't matter the manufacturer if you don't know how to tune it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-06-2015, 07:33 PM | #6 |
I tried all the different metering rods and different jets in edelbrock 1489 calibration kit with no luck. I finally had enought and put on 3310 yesterday. Im glad I did.
09-06-2015, 07:41 PM | #7 | |
Good move on the holley though. Now before you start tweaking the holley, optimize your timing first! |
09-06-2015, 07:51 PM | #8 |
It could be timing , it was 16* at idle, but I dont trust my dissy. I bought a complete other one, but ran out of time to install. This carb still pulls harder than eddy did... just my opinion
09-06-2015, 08:02 PM | #9 |
And it'll start better too!
Especially when it gets colder this fall. You did plug your vac advance off when you checked timing, didn't you? Have you proved your balancer/timing tab are correct? |
09-06-2015, 08:31 PM | #10 |
yes I plugged vacuum advance and no I didnt prove timing tab. That is a good point. Will check .
09-06-2015, 08:36 PM | #11 |
Info for you.
http://www.crankshaftcoalition.com/w...op_dead_center |
09-06-2015, 08:51 PM | #12 |
very good reading ...will read later..
09-06-2015, 09:02 PM | #13 |
heres my engine specs http://www.jasperengines.com/pdf/Cla...20Stroker%2009
09-12-2015, 08:48 AM | #14 |
I swapped everything over to Holley a couple years ago. The reason was how far Holley has come with their products. Power, mileage everything. Back to set it and forget it.
Don't get me wrong I'm a carb guy and have had Edelbrock, Quadrajets, old Holleys and a few oddball ones. These are all on daily driven vehicles and one weekend fun/race vehicle. |
09-12-2015, 09:30 AM | #15 |
Using the term set it and forget it and Holley in the same sentence? I guess things have changed.
"You can take the man out of PA, but you can't take PA out of the man" |
09-12-2015, 10:29 AM | #16 |
You haven't lived until you have a 1bbl Rochester B. LOL
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
09-12-2015, 11:49 AM | #17 |
Sorry to go off topic but is 750 cfm too big for a stock 396/402?
1971 Cheyenne Big Block Longhorn |
09-12-2015, 04:01 PM | #18 |
