09-08-2015, 01:58 PM | #1 |
WOT Sputter
I have put new heads, intake, distributor, and installed a new 600 cfm Quick Slayer Carb on my motor. I am beating my head against the wall, for some reason I have a sputter when you nail the throttle. I have adjusted the float and the air fuel mix screws and it still sputters. Is there something I am missing here.
09-08-2015, 02:49 PM | #2 |
Re: WOT Sputter
What is your timing set at?
09-08-2015, 03:13 PM | #3 |
Re: WOT Sputter
32 degrees
09-08-2015, 03:25 PM | #4 |
Re: WOT Sputter
09-08-2015, 03:45 PM | #5 |
Re: WOT Sputter
All I know off the top of my head is the total timing. I will have to get my buddy to come over and we will check the initial.
09-08-2015, 07:19 PM | #6 |
Re: WOT Sputter
I wasted a lot of time Saturday chasing a sputter, I timed it, changed the coil, fuel pump and then changed out the dizzy internals. All that work and it turned out to be the combo of a paper filter and a little water in the gas. It was all parts I had laying around so it wasn't expensive, just don't forget to start with the simple stuff.....
09-08-2015, 08:58 PM | #7 | |
Re: WOT Sputter
