Another Temp Gauge Question
My temp hand is pegged on H.
I ran a ground wire from the bottom nut on the gauge to the windshield wiper nut (just to see if it moved) it smoked the printed circuit board. I can see where it burned the copper wire on the circuit board. I'm going to buy a new board tomorrow . Is there anything else I should buy and/or do while I have the dash cluster out . I don't want to buy one and trash it again . Why did it burn it when I touched it to the wiper nut ? ![]() |
#2 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Re: Another Temp Gauge Question
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#3 | |
The silver post
The copper traces on the "circuit boards" can be easily repaired with a bit of soldering skill. Carefully peel/scrape back plastic covering broken ends of copper traces. Tin both ends of the broken trace. Place a piece of copper wire over the tinned ends and touch with soldering iron...done.
Msgt USAF Ret
Grounding a ground shouldn't have burnt the copper strip. Check the resistor and make sure there is resistance between the two posts.
What about the other tests?
pulled out the instrument cluster and the printed circuit was damaged where the main harness hook in. Put in a new printed circuit and fix my temp gauge problem.
Thanks for you help ! Problem solved. |
