Old 09-11-2015, 01:20 PM   #1
C21EddieV
Vapor Lock
I have a 69 Chevy C10. I live in So.Cal and it's been hot & humid! Twice this week I've had a vapor lock! Once in the fast lane on the fwy! What's the best way to correct this issue? I'd appreciate any advice.
Ed Vasquez
Exclusive Properties
951-712-0601 Cell
909-992-3692 Efax
Email: c21eddiev@gmail.com
C21EddieV is offline   Reply With Quote
Old 09-11-2015, 03:43 PM   #2
cdowns
cdowns's Avatar
Re: Vapor Lock
vapor lock is mostly an old wives myth it doesn't really exist// check your fuel system start at the gas cap and slowly work your way methodically to the carb
Old 09-11-2015, 04:07 PM   #3
Orence1
Orence1's Avatar
Re: Vapor Lock
Take a look at the location of your fuel filter/fuel line. I had a similar issue in that mine would start fine when cold but when hot it was hard starting during summer heat. No issues in cooler spring or fall. Fuel filter was down about mid block and was picking up a lot of heat. Moved it up the line to the top of the engine and near the carburetor. End of problem.
Orence1 is offline   Reply With Quote
Old 09-11-2015, 04:09 PM   #4
Mmorgan32
Mmorgan32's Avatar
Re: Vapor Lock
Same thing happened to me when I moved to Fresno. I put on an edelbroke 1/2 in thick heat riser. I just ordered it from summit and I shortened my fuel hose going to my carb cause it was touching my valve cover. Never happened again.
1972 gmc c15 short bed... Sold
1970 chevy custom camper patina daily driver
Mmorgan32 is offline   Reply With Quote
Old 09-11-2015, 08:21 PM   #5
C21EddieV
Re: Vapor Lock
Thank you all! Much appreciated!
Ed Vasquez
951-712-0601 Cell
909-992-3692 Efax
Old 09-11-2015, 08:25 PM   #6
Tillik
Tillik's Avatar
Re: Vapor Lock
I bent a new Fuel line from my mech pump. Wrapped it in Heat Tape. That helped a ton but the Phenolic? Spacer pretty much eliminated my issues with that. Good Luck
James B.
1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful)
1971 Chevy Fleetside Shortbed 4X4 (White & Rough)
Tillik is offline   Reply With Quote
Old 09-17-2015, 02:11 PM   #7
MagmaJct
MagmaJct's Avatar
Re: Vapor Lock
I had that reoccurring issue. It progressively got worse until the truck refused to start, and had to be towed home.
From there I diagnosed the problem to a failed fuel pump. Once I replaced it, I've never had vapor lock symptoms again. And I live in the Arizona desert, and that was probably 4 - 5 years ago!
Apparently, a pump can show these symptoms as a precursor to complete failure. I don't know if I'd performed a pressure test if I would've seen any problems.
Regards,
Mike
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
