Old 09-12-2015, 07:34 PM   #1
roxxx
looking for upgraded suspension for C10 SWB
Hi Folks I picked up a stock C10 1972 SWB and want to do brakes and suspension no lowering other than some bigger wheels
I know porter makes a kit but is there any other full kits ? shocks brakes sway bars
roxxx is offline   Reply With Quote
Old 09-12-2015, 10:12 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: looking for upgraded suspension for C10 SWB
No "lowering" but you're looking at Porterbuilt? I'm confused.
If you're leaving it at stock height... Almost everything you need can be bought from a local parts store. Such as a NAPA.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-12-2015, 10:46 PM   #3
roxxx
Gary
Okay I want to stop and I don't want to wallow going around corners porterbuilt makes upgraded trailing arms and frame stiffeners plus a bunch of other things for stock ride as does hotchkis suspension makes new geometry Arms better shocks and so on
I don't think Napa sells this stuff , I don't need to lower it to make it handle just want to update the 40 ish year old suspension
Old 09-12-2015, 10:57 PM   #4
GASoline71
GASoline71's Avatar
Look at CPP's tubular trailing arms you can get them in a complete kit with shocks and a new cross member too.
Just seems like a lot of coin for a stockish ride. But hey, it's your rig.
All the disc brake components for the front can be bought at a local parts house. But if you want to upgrade the rear brakes to disc as well, then CPP and ECE sell rear disc brake kits too.
Gary
Old 09-12-2015, 11:06 PM   #5
roxxx
Gary
Thank you
I have one other project I am working on and it is going to be a lowered 1972 SWB portbuilt and also have a 4x4 swb 1972 which is in storage . picked this up 5 months ago and just drove it and decided on what i am going to do to it suspension is a must plus some other stuff
Old 09-13-2015, 01:09 AM   #6
mike16
rebuild whats worn out, new shocks, radials and anti sway bars front and rear. that will do you as good as any "kit". 72's came standad with disc brakes so your good there.
mike16 is offline   Reply With Quote
Old 09-13-2015, 08:24 AM   #7
TwinsSpeedShop
I went with the full GSI kit, but it's for bags and laying frame. Hope to be installed in a month or so
TwinsSpeedShop is offline   Reply With Quote
