Old 09-16-2015, 04:49 PM   #1
summitflier
summitflier's Avatar
Rear trailing arms
I took my rear trailing arms off about a month ago,
I put one on the right side of work area, and the other on
the left side of my work area. However they were moved.
So now the question is... is there a difference between the right
side and the left? They mostly look the same, but one has a
couple of holes in it that the other side doesn't have.
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline   Reply With Quote
Old 09-16-2015, 04:51 PM   #2
Xeen
Xeen's Avatar
Re: Rear trailing arms
There will be a bracket for the parking brake cable on each trailing arm they go on the outside, once you look at it there is only one way they can be installed.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-17-2015, 12:28 AM   #3
TBONE1964
Cluster King
TBONE1964's Avatar
Agreed. If you are not running a park brake then there is not a wrong way. With out the bracket, the trailing arms are identical, left to right. The brackets for the park brake (like Xeen mentioned) is the only difference between left and right and the only way to install them correctly is with the bracket on the outside.
Hope this helps,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
