09-16-2015, 11:59 PM | #1 |
Serial # question: Has anyone seen this before?
Both of the frame serial numbers on the 67 C10 I bought are struck out the same way. The corrected serial number matches the VIN tag on the cab. It's obvious this happened at the factory, but has anyone seen anything like it before?
-------------------- Steve |
09-17-2015, 12:07 AM | #2 |
Re: Serial # question: Has anyone seen this before?
I have seen something similar on a Mazda before so I know it does happen...
This was a 1990 so a lot newer. |
09-17-2015, 12:23 AM | #3 |
no. but it makes sense that it's one digit off, like they forgot to change the die.
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
09-17-2015, 06:23 AM | #4 |
I've seen struck through numbers on the Corvette forums
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
09-17-2015, 07:15 AM | #5 |
Yep. Someone was having a bad day.
The VIN stamper is a large hydraulic "press" hanging from a tool rail and with the weight offset by a "balancer" (imagine a Harley-Davidson hanging from the ceiling that you are supposed to maneuver into position and press a button). It is supposed to index to the next digit automatically -but - if you mis hit or get out of sequence for some reason then you have to make a repair. Chevy and GMC have different VIN sequence numbers, requiring different stampers hanging there, so if the operator stamps a Chevy VIN on a GMC, for example, then not only is that particular truck wrong but you are out of sequence on every truck after that. The assembly line repair person and/or the "quality man" (the foreman's right hand man) follow the vehicles down the line with an "X" stamp and a 5 lb hammer and correct the VIN sequence number as required. Usually it's not just one truck. It normally takes several trucks before somebody notices, so you'll have five or six trucks that have to be fixed - all without the line stopping - so it's quite a scramble for a few minutes while you figure out what happened and what has to happen to make it right. You pray nothing else goes to crap while you've got your two best guys otherwise unavailable. Cool pics - thanks for posting those. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-17-2015 at 10:24 AM. |
09-17-2015, 10:54 AM | #6 |
So my 67 gmc has no stampings at all on my frame in either location. Could this have been missed down the line? I had it blasted and coated and you can tell no one has grinded them out or messed with the frame in these areas.
09-17-2015, 11:32 AM | #7 |
Excellent responses! And special thanks to Keith for the cool history lesson. It adds nicely to the story line of this truck.
09-17-2015, 11:57 AM | #8 |
All about them K’s
I've heard before that the 67-68 gmc didn't always have the partial vin stamped on the frame. I've also read some didn't have Spids as well.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
09-17-2015, 03:21 PM | #9 |
Florida Edition
We have a 70 GMC short bed Sierra Grande with no VIN stamping at all so I know it happens.
Also a couple of our 67's definitely didn't come with spids.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
