09-18-2015, 06:28 PM | #1 |
Won't Idle When Put In Drive
My 1972 350 w/4wd starts and idles fine but when I put it in drive the motor dies. Any suggestion on what the problem is? Thank you in advance for any advice you can give me.
09-18-2015, 07:29 PM | #2 |
Re: Won't Idle When Put In Drive
Common symptom of a vacuum leak.
09-18-2015, 09:45 PM | #3 |
Or a lack of initial timing!
09-18-2015, 10:08 PM | #4 |
Old member
What is the RPM's @ idle before putting in gear. A auto should be around 700RPM and maybe a little more.
Stock motor you should check base timming first with no vacuum applied. Then hook vacuum up and check again
