Old 09-19-2015, 04:08 PM   #1
merlin3
leaking headers
when replacing my new failed starter i noticed my headers are leaking these headers are designed not to use gaskets but they leak everywhere i am trying to get to the shop for a complete exhaust is there any thing i can use? gasket sealer? i tried copper header gaskets and they still leak.thanks
merlin3 is offline   Reply With Quote
Old 09-19-2015, 04:14 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: leaking headers
The main thing that makes headers leak is over tightening of fasteners. Once the flange on the collector and the flange on the head are warped they will leak like crazy.
What brand of headers? Are they a ball and socket design on the bottom collector? Use a thicker gasket for the head flange and tighten from the inner 2 siamesed tubes outward.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-19-2015, 06:37 PM   #3
merlin3
Re: leaking headers
they are not the ball and socket style.they leak on the head,i will try different gaskets, they are Sanderson headers and i made sure not to over tighten the head flanges, i thought the copper gaskets were the best? thanks
Old 09-19-2015, 08:26 PM   #4
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Re: leaking headers
According to the Sanderson Website, they recommend using no gasket, just RTV sealant. That won't matter if the flanges are already deformed. Just my 2cents worth!
TobyArnot is offline   Reply With Quote
Old 09-19-2015, 08:45 PM   #5
BigMike
BigMike's Avatar
Re: leaking headers
I have Sanderson shorty headers on my truck (I believe CC11?) and they have never leaked. I use the black RTV as they suggest (I think thats what it was, been so long). I put a little bit on the ends of the header bolts too and they've never backed off. I repainted my engine after taking it out to fix a couple oil leaks, I scraped the old black RTV off, applied new, put the header on a little more than finger tight and then went back out the next day and tightened them more. Never had an issue. Now I don't think you have to wait 24 hours to tighten them back up, but it's worked both times I've done it and never had any issues at all.
BigMike is offline   Reply With Quote
Old 09-21-2015, 08:40 AM   #6
snipescastle2
snipescastle2's Avatar
Talking Re: leaking headers
I have used the replacement manifold gaskets that come with a standard rebuild kit(the perforated metal/composition type) with good results, the factory never used gaskets on the manifold to head surfaces. I stopped using header gaskets long ago, no sure fire way to keep them from blowing out. I work for a utility company and we have a gasket material called "Grafoil" like graphite gaskets with a wire screen impregnated inside, I'm going to try and make a set of these and see how they do, problem is, this material is prone to splitting when punching out holes, almost have to use a hole saw to cut it without tearing/splitting....will keep everyone posted on how it works out.
Have a good one!
Ben
snipescastle2 is offline   Reply With Quote
Old 09-21-2015, 12:36 PM   #7
leftybass209
leftybass209's Avatar
Re: leaking headers
When you say you "made sure" you didn't over tighten them, did you use a torque wrench? There's a fun little game to play on people in shops that don't use torque wrenches: have them tighten 4 bolts with a ratchet to what they feel is the same torque spec. Then have them verify with a torque wrench. None of the bolts will be tightened to the same spec.
leftybass209 is offline   Reply With Quote
Old 09-21-2015, 05:34 PM   #8
merlin3
Re: leaking headers
thanks bigmike i will try that,leftybass thats a good point but how does one get a torque wrench on those header bolts?
Old 09-21-2015, 07:27 PM   #9
mike16
Re: leaking headers
some times if you separate each runner from the others at the head flange by cutting out the section of the flange between runners. you can minimise and even eliminate the effect of warping.and if only one runner/flange is warping it does not influence others.
its the heat that warps them. it also causes hardware to loosen up. when that happens people will go in and snug the hardware up, often while the header is too hot to touch.
wait until the header is cool to the touch, torque it properly, and use safety wire on your hardware to maintain that torque. If it is found to have loosened up, back the bolt off, retourque it and safety it up. done right, eventualy the header will stabalise and the bpoblem will go away. crank on it wrong and not only will those problems remain but improper torqueing on hot parts will cause several other problems as well.
mike16 is offline   Reply With Quote
Old 09-23-2015, 05:16 AM   #10
snipescastle2
using a "Crow's Foot" is about the only way to get in between the tubes to torque them down, if you can at all.....Ben
Old 09-23-2015, 08:26 AM   #11
Re: leaking headers
I have never torqued headers and don't have issues with headers leaking. The cheap gaskets they always gave you didn't help, so I used to have to tighten them from time to time on a couple trucks. The headers that are on my '72 I have now I installed in '01 and have yet to touch them. The exhaust system I had made at that time is showing it's age. One rear bracket weld broke loose and one side rusted off at the muffler. I have that coupled together, but time to think about new exhaust. I guess I'll go ahead and replace the headers while I'm at it.
Old 09-23-2015, 11:18 AM   #12
nzc10
nzc10's Avatar
Re: leaking headers
I had issues with leaking header gaskets ended up putting two gaskets together then fitting no problems now
"I ain't got no time for side tracks!"
69 R/T Charger
72 C10 Chevrolet
85 302 Jaguar
99 955 Daytona
10 1050 Speed Triple
nzc10 is offline   Reply With Quote
