Old 09-20-2015, 07:27 PM   #1
Softpatch
Softpatch's Avatar
59 TF hand brake question
I bought this spring for my hand brake
can't seem to figure it out .
I feel like I'm missing something .?
before I modify/destroy the spring
I thought I would ask the question
It looks too long shouldn't it go in the hole and the spring center be around the handle Pivote bolt .?..
....Thanks Sp
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 09-20-2015, 07:52 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 59 TF hand brake question
the spring is the right one. The bent end goes up the stamped steel handle and the shroter end slides into that hole of the cast handle, you need to clean out the rust and possibly the end of the broken spring so it will slide into the handle
dwcsr is offline   Reply With Quote
Old 09-21-2015, 03:00 PM   #3
Softpatch
Softpatch's Avatar
Thanks dwcsr
I just could rap my mind around it I was first thinking I need to pinch the spring in a "V" shape
then i saw your picture tried it worked out simple thanks again ....Sp
Old 09-21-2015, 03:12 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
don't feel bad, I spent about an hour figuring out the same thing and decide to take a picture for next time
