Window Seals
I bought the UPPER window seals through GMC PAULS.
The outer is a squeegee, the inner is the felt. When I line up the clips with their corresponding holes, the seals seem too long to fit into the door opening. Are they supposed to be trimmed, OR are they supposed to lay over the wing window trim and into the window guide? I'm trying to find them in the assembly manual but I must be over looking.
A man's thoughts devise his ways; but it's GOD that directs his steps. |
![]() Join Date: Nov 2011
I have the same ones and yes I had to trim them using my dremel with a cutoff wheel installed. Just take your time and measure twice before you cut.
Re: Window Seals
Will do.
Thanks for the reply. Yeah I've been there more times than I'd like to admit. Measure twice; cut once. I always remember that after it's too late.
![]() Join Date: Sep 2015
Re: Window Seals
I believe brothers trucks have a video on replacing the windows seals. If you get stuck maybe check that out?
