09-23-2015, 11:47 PM | #1 |
rock autos replacement radiator
has any body used rockautos replacement radiator number CU369 made by spectra premium. the days of copper brass are 99% over. the spectra rad is aluminum with plastic tanks and is supposed to be 100% drop in fit. I ordered one from rockauto,it was 151.00 delivered,auto zone had same rad for 189.00 + tax.
thanks bob
I BELIEVE IN JOHN 3:16 |
09-24-2015, 12:26 AM | #2 |
Re: rock autos replacement radiator
There are many people on this forum using that radiator and all seem to be very happy. It is just as good as stock just does not look as cool.
1971 Cheyenne Big Block Longhorn |
09-24-2015, 12:42 AM | #3 |
OMGosh that means my Advanced Auto radiator is probably plastic and aluminum too. I haven't unboxed it yet.
I'll try and get something real later. |
09-24-2015, 12:59 AM | #4 |
yep I bet its alum/plastic too. when I worked on semi trucks a few years back I noticed the rads was alum/plastic and went over 1 million miles but they took the red lifetime anti freeze made for alum rads.
09-24-2015, 06:55 AM | #5 |
Thats the one I got when I dropped in the bigger engine. mine originally had a 6 cyl in it and the top and bottom saddles were too narrow(for 2 core rad.) so I modified the saddles instead of buying the right ones, everything turned out great. nice fit. I'm happy with the rad. if you already have the 8 cyl. engine it should be a drop in fit..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
09-24-2015, 04:55 PM | #6 |
is your rad alum/plastic ? alsoy truck is 6 cyl so what would ne the perfect way to mount this rad please ?
bob
09-24-2015, 07:18 PM | #7 |
Zappaphile!
I picked mine up from O'Reilly's a year or so for $130ish, and was stunned.
Damn thing was spot on (minus a few manufacturing tags) to the factory unit I pulled out. All metal and very very well built. 4 core unit.
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son |
09-24-2015, 07:36 PM | #8 |
There's no way I'd put a plastic end tanked radiator in my '67. I went with an all aluminum one which is still ugly but not as bad as plastic.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
09-24-2015, 07:56 PM | #9 |
Old member
For the money I would buy one of these. No plastic at all is the only way to go!
http://www.ebay.com/itm/3-ROW-ALUMIN...f0c567&vxp=mtr
09-24-2015, 08:12 PM | #10 |
Plastic, aluminum, go with what you like. I thought about the aluminum ones till alot of guys were stripping the aluminum threads out where you hook up the trans lines, plus I think the PLASTIC one when painted black looks more original than the boxie tig welded units. just my opinion..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. Last edited by hamjet; 09-24-2015 at 08:22 PM. |
09-24-2015, 08:25 PM | #11 |
Old member
When it comes to my truck and engine I go with how well a product performs over looks everytime!
09-24-2015, 08:40 PM | #12 |
Very true Andy, I've researched the different rads and the majority of the reports on the Spectra Premiums were not bad, and so far, fingers crossed, I won't have any problems..
09-24-2015, 08:52 PM | #13 | |
Old member
I had the radiator O-Reilly sells in my truck up til a week ago. They replaced it once and it was leaking again so I bought a complete aluminum one for $157.00. No plastic. It fits well in mine with some minor mods on the bottom supports. Here is the link. http://67-72chevytrucks.com/vboard/s...d.php?t=681842
09-25-2015, 02:02 PM | #14 |
I don't want to hijack this thread but I picked up a new CU369 rad this week. I discovered that I'll need the larger retainers as it much thicker then the Spectra CU840 that's currently in the truck. The issue I'm having is that the bottom rad hose comes off the rad at about 45 degrees instead of 90 like the CU840. It looks like the hose might also interfere with the transmission cooling line. Anyone else run into this issue? Do you have a part # for the hose that will work with this setup? Did you have to re-route the tranny line?
In the pictures of the aluminum rads above, one seems to come off at a 90 where the second one is angled up (like my new CU369).
1967 C10 SWB Small Window |
09-25-2015, 02:21 PM | #15 |
My OE radiator is curved upwards. The pics in this thread all appear to angle upwards.
My transmission lines have a double curve to avoid the lower hose neck.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
09-25-2015, 02:42 PM | #16 |
Here's the one I'm using. It's a reasonable price all aluminum, two row with 1" tubes. I've been using it in the hot West Texas sun for the last two summers and it now has over 7000mile on it. Oh, and it's made in America by Americans.
http://www.speedcooling.com/1967-197...r/prod_38.html
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
09-25-2015, 02:49 PM | #17 |
Another view
09-25-2015, 07:33 PM | #18 |
our trucks are supposed to be angled up on the lower hose connection... thanks for all the imput fellas.
