09-24-2015, 09:54 AM | #1 |
1967 C10 1/2 ton small back window question
I'm looking at buying a 1967 C10 and was wondering if they all came with a small back window? The one I'm looking at has a large back window. So it's kind of throwing me off.
Thanks |
09-24-2015, 09:58 AM | #2 |
Re: 1967 C10 1/2 ton small back window question
The large window was an option in '67, and the small window came as the base size. So the trucks came with both in that year. The truck is more than likely still a '67.
1971 GMC C2500 - 350 SB - 700R4 1972 Chevy C10 - 350 SB - TH350 |
09-24-2015, 10:19 AM | #3 |
Awesome! Thanks man! Makes me feel better
09-24-2015, 09:45 PM | #4 |
A better way to identify a 67 is if it has no side marker lights.
1968 C10 SWB "Rosey" |
09-24-2015, 10:00 PM | #5 |
09-24-2015, 11:23 PM | #6 |
I had a mamber tell me not long ago, later 67's like mine had side marker lights in the front, just not wired up. And mine is also a large back window 67
09-24-2015, 11:32 PM | #7 | |
Roadtrip!
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
09-24-2015, 11:54 PM | #8 |
I believe the '67 big back window option is called "panoramic cab eq" on the spid. I would check the spid (glove box sticker), vin plate, and frame vin stamp when considering purchasing any old trucks. Too much swap-a-rooo stuff being passed around nowadays.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
09-25-2015, 12:06 AM | #9 |
…then again, the truck you are looking at might be a mutt.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
09-25-2015, 12:57 PM | #10 |
look at the ignition bezel. most likely the dash has not been swapped and 67 has a smaller ignition bezel than 68-72. there are many clues if you search on how you can tell if a big window cab is a 67 or 68-72. firewall by the heater unit is different stamped a little different. rear view mirror I believe is a one off in 67 and the mounting hole design for it is reversed in 68-72 if it had one at all.
