Old 09-26-2015, 10:34 AM   #1
markiemark
Help with wheel sizing for tubs!!!
I recently purchased a 70 short bed (pictures to follow). It is fully tubbed and I would assume narrowed rear end. It came with 15" Weld wheels with 32x17.5 r15 et streets and I'm looking to go larger. What would I need as far as measurements if I wanted to order a set of wheels. I'm looking at 20"x12" wide or larger. Thanks in advance...
markiemark is offline   Reply With Quote
Old 09-26-2015, 02:37 PM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Help with wheel sizing for tubs!!!
When I did my tubs, narrowed my rearend and ordered my 19x12's I used this:
Seriously... I would start with measuring the dimensions (mainly the backspacing) of the wheels on it now, the clearance they have and go from there. The width of the rearend, the size of the tubs, etc. There are many threads on this site about this.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 09-26-2015, 03:34 PM   #3
Redline novdog
Redline novdog's Avatar
If your sheet metal is complete the measure. I ordered 14" wide Cragars for the Novdog with special backspacing,should have been 1/4" less backspace nothing I cant fix but more work. Those are 33x15x15.You have alot of measuring to do.If you're gonna use the rearend you have then measure it and compare to factory! Sounds like a wheels up project(the front of coarse!)
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
