Old 09-26-2015, 01:26 PM   #1
Brave71
Door won't open!,,
My passenger door will open fine from the out side and the lock works fine ...but door won't open from the inside, I took off the door panel everything looks good.i think the latch is repop..should I get a new one or am I missing something? Thanks for your help
Brave71 is offline   Reply With Quote
Old 09-26-2015, 02:07 PM   #2
Redline novdog
Redline novdog's Avatar
Re: Door won't open!,,
If all the linkage is hooked up I would say junk latch.IMO!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 09-26-2015, 06:43 PM   #3
hugger6933
Make double sure that the relay is working properly before junking the latch. If it is working then it is time to move on to the latch and replacement.
hugger6933 is offline   Reply With Quote
Old 09-27-2015, 08:22 AM   #4
John Pasinski
John Pasinski's Avatar
Check the inside of the door at the bottom. Same thing similar occurred with my pass. door. I found the rivet broke and relay was laying down inside. Reattached with a screw and ny-lock nut leaving just enough play for the relay to pivot. A latch is something $65.00 if I recall.
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
