Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-27-2015, 06:44 PM   #1
dinnut
dinnut's Avatar
Converting from power steering to manual
I want to get rid of the power steering on my 70. What all needs to be changed to put a manual box on one of these trucks? I've lost the power steering belt too many times and it's always at the worst time!
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 09-27-2015, 07:46 PM   #2
redsled87
redsled87's Avatar
Re: Converting from power steering to manual
Honestly not much. I switched out my 87 and all I did was unbolt the power box and draglink and put the new one on. The boxes are the same from 67-87. Mine came with a draglink on it so I used it. I'm also asumming your talking about 2wd drive also.
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 09-27-2015, 07:50 PM   #3
djracer
djracer's Avatar
Sounds like the same thing I did!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-27-2015, 08:14 PM   #4
dinnut
dinnut's Avatar
2wd yes. Sounds easy enough! I was concerned with the rag joint side of the box. Everything is the same on that side too?
70 longbed
496/th400/Ford 9"
Old 09-27-2015, 09:19 PM   #5
Ont67shortbox
mine used to float on the top end with the power steering,was hard to control, I just cut the hoses and put a joiner in a couple clamps ,now its 100 % better and it cost me $3,for the hose joiner and clamps I kept the pump so all I have to do is replace the hoses and have ps if I decide to sell it
Ont67shortbox is offline   Reply With Quote
Old 09-27-2015, 11:18 PM   #6
dinnut
dinnut's Avatar
I lost the belt during the burnout last weekend and didn't know it. It spun and went right and with no power steering I couldn't correct very fast and had to lift to avoid hitting the wall!
70 longbed
496/th400/Ford 9"
Old 09-28-2015, 04:27 AM   #7
BigDan3131
BigDan3131's Avatar
I see it as an either or situation. Either spend the time to convert it and regret it later on or upgrade to a serpentine belt drive and not have to worry about the belt coming off.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 10-03-2015, 10:39 PM   #8
dustin72
dustin72's Avatar
I had problems with throwing the power steering belt too, until I upgraded everything to March v-belt aluminum pulleys. That was over 10 years ago and I haven't thrown a belt since. Shifting at 7200+ RPM.
dustin72 is offline   Reply With Quote
