Old 09-28-2015, 08:13 AM   #1
YourBuddy'sTruck
YourBuddy'sTruck's Avatar
Broken Starter Bolt
I know what I'm doing after work today....
So, I was swapping spark plugs and dropped #8.
As I grumbled to my knees to pick it up, I found the outer starter bolt laying there in the drive.
It's sheared right at the threads as would be expected.
So now I've to drop the starter and get that partial bolt out of there.
Anyone have stories or advice on this?
A favourite Easy Out to use?
It is a hardened bolt, so what I have may not cut it?
Any input would be helpful
(Laughing at me is acceptable too)
YourBuddy'sTruck is offline   Reply With Quote
Old 09-28-2015, 08:38 AM   #2
Mike C
Mike C's Avatar
Re: Broken Starter Bolt
Crazy. If a starter bolt is the correct size it shouldn't ever be bottomed out in the hole, just under tension between threads and the starter. If not cross-threaded it should come out fairly easy.
Knock wood...
I would try either a reverse drill bit or one of those extractors that you run in a drill in reverse. But it might unthread by hand.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-28-2015, 08:55 AM   #3
bill3rail
bill3rail's Avatar
Grind it to ensure the drill bit is centered, and use a left hand drill bit, add heat and drill away.
bill3rail is offline   Reply With Quote
Old 09-28-2015, 12:24 PM   #4
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I had mine shear off clean at the block while I was driving. Discovered it when the starter did the grind at the next start up.
I was able to grip the remains with a rag pressed against it & slowly twisting it out until I could get pliers on it. I bought ARP starter bolts to prevent that problem from ever happening again.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 09-28-2015, 02:20 PM   #5
cdowns
cdowns's Avatar
a starter bolt is not hardened just a normal over the counter grade 5 is normal
Old 09-28-2015, 02:56 PM   #6
leftybass209
leftybass209's Avatar
Haven't had a starter bolt break, but I did have a main cap bolt break when I tried to verify torque. It must have been at its absolute limit because I didn't even get 10 lbs of torque on it before it gave. Came out really easy by hand.
Best of luck!
leftybass209 is offline   Reply With Quote
Old 09-28-2015, 06:36 PM   #7
YourBuddy'sTruck
Went off without a bang.
Couldn't find a reverse drill bit, but that would've done it quick!
It was not even finger tight, but up in there.
Quick drill and easy out pulled it right out.
Thanks for the replies!
Old 09-28-2015, 11:38 PM   #8
In The Ten Ring
Glad that proved easy.
Since beginning work on the truck, I have had to drill out two broken bolts. One of the gas tank bolts to the cab floor and the other was a hood bumper bolt (in a replacement grill bracket).
The former I really had a mess....not knowing how to use an "easy out" I broke the head of one off in the bolt! I had to grind it out with my dremel tool and then dad drilled through it, getting it out with a flutted easy out he had (Proto?). The latter I just drilled out until it was completely gone. I'll use a tap set to clean out the threads on the bracket's threaded portion.
Lots of things to learn rebuilding these trucks!
In The Ten Ring is offline   Reply With Quote
Old 09-29-2015, 07:50 AM   #9
Aruba1
HF has a nice set of left handed drill bits and amazingly they are very sharp. https://www.youtube.com/watch?v=PfpH4dxYJ6g
Aruba1 is offline   Reply With Quote
