Old 09-28-2015, 09:44 AM   #1
tsetsaf
LS Cruise Wiring - Problem
When we restored the truck I bought a generic wiring harness not realizing it was missing the proper running lights/ turn signal wires for a 71. I have been rolling around the last 2 years with the side markers wired to turn signal only, and the front orange parking lights also tied to only turn signal. This means that when lights were on only my headlights and tail-lights were lit. Side markers and front parking lights were dark except in the following:
1. Apply the brakes the two rear markers lit
2. Flip on turn signals the side markers flashed and the front parking light flashed (on the appropriate side of course)
Over the weekend I adjusted the configuration by splicing the two rear side markers to the running light wire heading to the brakes. They now are on with the lights and do not flash.
I then ran a new wire from the panel to the front markers and running lights while removing their connections to the turn signal wiring. Result = markers only on with lights no flashing. Running lights are on with lights and flash brighter with signal.
PROBLEM: Now my cruise control will not engage. I can flip the button on and get the "cruise ready" light but clicking the "Set" does nothing. Any thoughts on where things might be off?
71 C-20 Custom Camper
California Truck
tsetsaf is offline   Reply With Quote
Old 09-29-2015, 05:05 PM   #2
tsetsaf
Re: LS Cruise Wiring - Problem
Anyone have issues with resistance on the brake wire using standard tail lamps?
California Truck
Old 09-29-2015, 06:35 PM   #3
hamjet
hamjet's Avatar
I feel your pain and I'm sure no one's ignoring you, Sorry, I can't help..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 09-29-2015, 10:03 PM   #4
ls1nova71
ls1nova71's Avatar
The front side markers were originally hooked to the park light wire in the front, which is the way you have yours, but instead of grounding the other wire, hook it to the power wire to the turn signal. That way they flash with the turn signals when the park lights are off, and when the park lights are on they will flash opposite the turn signals.
As for the cruise, are you sure you still have power to the cruise switch? Is it DBW or cable?
Did you change anything else?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
