Old 09-28-2015, 08:36 PM   #1
70c10guy
help me!!
Hi all,
Last post was about headgaskets.. well finally did the install. 416 heads, holley 650 dp, and msd hei. Can't get it running right. This is on a 1970 c10 with a 307.
Got iti idling decent, let it warm up, then set the timing to 10 degrees btdc. I started off with the idle screws at 1 annd a halfturns out. It shut off on me and now won't start back up, acts like the battery is dead but I just had it idling for about 30 mins. Alternator is new and so is battery. First thing is obviously check cranking amps and volatge.
Also another thing when I hooked a vacuum gauge to the carb, it pegged to 30".. idk what to do next.. hep please!! Someone!
70c10guy is offline   Reply With Quote
Old 09-28-2015, 08:50 PM   #2
Jrainman
Jrainman's Avatar
Re: help me!!
clean your battery terminals ,first take them off clean them up real good the check your grounds if problem still presists
Jrainman is offline   Reply With Quote
Old 09-28-2015, 09:08 PM   #3
71swb4x4
71swb4x4's Avatar
Re: help me!!
New parts don't mean good parts. Or maybe you hooked the alternator up and you weren't charging. Don't good too discouraged, start at the basics and work your way through it again.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-28-2015, 09:52 PM   #4
70c10guy
Re: help me!!
Hey thanks guys! Will try checking the wires to the alternator. What about my 30 inches of vacuum issue??
