Old 09-28-2015, 08:57 PM   #1
chico68
roof skin replacement (galvy spray?)
I am preparing to do an inner and outer roof skin replacement, I have sand blasted these parts and was wondering if anyone has tried the galvy spray that's out there. I would like to coat the panels before welding them up as to give them a lot better protection than the factory did (bare steel). I will use weld through primer at the weld areas, but need some feedback on the galvy spray. Thanks Rob P.
chico68 is offline   Reply With Quote
Old 09-29-2015, 07:36 AM   #2
Re: roof skin replacement (galvy spray?)
I have used that. I don't know what is galvanized about it, but welding galvanized is bad news. It will burn/melt where you weld. There is a weld through primer you could use in welded areas
Old 09-29-2015, 09:28 AM   #3
drewbert41
drewbert41's Avatar
You have any pics of the inner/outer removal?
drewbert41 is offline   Reply With Quote
Old 09-29-2015, 09:45 AM   #4
cooperhw
cooperhw's Avatar
How many hours and cost do you think you will have in this inner/outer roof panel replacement. Just wondering. I also had this to do on my 68, including the back of the cab as it was a converted motor home from new. I figure I had about $500 and about 40 hours into the repair. Just wondering how that compares?
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 09-29-2015, 06:06 PM   #5
chico68
I have a couple of pics of the donor roof pieces after I drilled out all the spot welds and separated them, and there are MANY spot welds. I will try to post these and any future pics from the roof project. Well cost wise the donor roof cost $50 from a salvage yard just sawzalled it right off. Time into this so far 5 to 10 min. to cut it off, 1 and 1/2 hours to drill out spot welds and separate the pieces, sandblasting the skins 30 to 45 min. I got lucky I found a donor roof with decent inner and outer skins, they will need some work but at least I have the complete inner skin, since they don't press that complete panel yet.
Old 09-29-2015, 07:34 PM   #6
Taibo
That galvanized spray contains a lead compound. Not only will it contaminate your welds but it will give off very toxic fumes when you get it hot and lead poisioning is a cumulative poison. It never leaves your body, but if you are serious about trying for a "Darwin Award" have at it!
Taibo is offline   Reply With Quote
Old 09-29-2015, 07:54 PM   #7
hugger6933
Why not just use some thing say paint? Use weld through about 3 inches pat the pinch welds should be plenty then paint the rest spray can or anything is better than what the General did[nothing]. Jim
hugger6933 is offline   Reply With Quote
Old 09-30-2015, 12:31 AM   #8
swamp rat
swamp rat's Avatar
Weldable primer maybe?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-30-2015, 12:52 AM   #9
Clavo106
X2 ^ / DO WHAT THIS MAN SAYS
Clavo106 is offline   Reply With Quote
Old 09-30-2015, 07:09 AM   #10
hugger6933
Tell that to my wife and kids. Just kidding
Old 09-30-2015, 07:26 AM   #11
.....There is a weld through primer you could use in welded areas
X4 ^ / YEAH! DO WHAT HE SAYS
Old 09-30-2015, 09:29 AM   #12
swamp rat
swamp rat's Avatar
Eastwood also has a couple products designed to spray into crevasses, its in an aerosol can and has an 18" hose with a nozzle, i believe one is for inclosed frames, the other is for body but ether would work to reach into areas after your done welding.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-30-2015, 11:24 AM   #13
Shaky
Six in a row makes it go...
Shaky's Avatar
We used glue for a good portion of mine. Check the C20 thread in my sigline.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
