Old 09-29-2015, 03:07 PM   #1
shak01
"My Lights Are Blinking" Quick Tip
Because the 1967-1972 cab and radiator supports are separated from the frame by rubber mounts. GM used a small mount woven wire ground strap that by-passes one cab mount. This insures electrical flow even if the cab mount bolts become rusted and electrical current can not flow properly.
You must be under the cab to see this by-pass cable. Yes, GM planned for the trucks later years when rusty mounting hardware caused the lights to dim.
Courtesy of Jim Carter
shak01 is offline   Reply With Quote
Old 09-29-2015, 03:49 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: "My Lights Are Blinking" Quick Tip
Ground straps. There will also be one from the fire wall to the rear of the engine at the passenger side and then on the drivers side from the engine to the frame. As well as one attached to the passenger side inner fender and then to the frame.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-29-2015, 04:21 PM   #3
raggedjim
raggedjim's Avatar
I have a question. When I pulled off my radiator support one of the mounts had a steel strap that kinda wrapped around the support bushing. Is it some kind of grounding strap? When I took it off I though it was to help hold the bushing parts together, but now I'm not so sure...
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 09-29-2015, 04:23 PM   #4
GASoline71
GASoline71's Avatar
It is a grounding strap.
Gary
