Old 09-29-2015, 08:47 PM   #1
RyansToy
RyansToy's Avatar
HEI on a 1968 250 I6... Weights?
So I am trying to chase some driveability issues I am having.
Purchased the truck a few months ago. Carb was leaking and I rebuilt it with new gaskets and a brass float. I may have been pretty passive driving it before the carb rebuild. After the rebuild I tried adjusting the timing too - basically checking everything is in order...
So now I have no leak, but the truck seems to stumble a bit when you floor it.
So far I have replaced;
spark plugs
plug wires
distributor
rotor
fuel filters
fuel pump
air filter....
I am left with the distributor weights/module/coil, and the fuel supply in general.
Can anyone confirm the weights on their HEI's?
"452" is on the center section
"106" is on the centrifugal weights
Can I check the springs? or are they standard?
Tomorrow I figure I am going to buy some fuel line and put a temporary fuel supply (jerry can) straight to the pump - by the battery and go for a drive.
Comments? what weights should be there? What can I do to verify the weights and advance?
I adjusted the carb fuel mixture using a vacuum gage. It seems to pull about 18ish inches of mercury. The vacuum actuator seems to work fine on the distributor (pulled vac with a pump).
RyansToy is offline   Reply With Quote
Old 09-29-2015, 08:47 PM   #2
RyansToy
RyansToy's Avatar
Re: HEI on a 1968 250 I6... Weights?
Is there an advance curve with regard to RPM? Something I can check the distributor function with regard to?
Old 09-29-2015, 09:02 PM   #3
RyansToy
RyansToy's Avatar
Just learned the vac advance diaphram is stamped with the Vac advance = 20 degrees.
Old 09-30-2015, 05:49 AM   #4
Shaky
Six in a row makes it go...
Shaky's Avatar
I've always just left the HEIs with the weights they came with, until I came across this in some thread on this site. I haven't tried it, but I want to someday:
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
