Old 09-30-2015, 09:20 AM   #1
George Bissinger
72 C10 Transmission information needed
I have a 1972 c10 with a 350
3. speed manual transmission that I would like to change to a 3 speed with overdrive any help
George Bissinger is offline   Reply With Quote
Old 09-30-2015, 10:52 AM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 72 C10 Transmission information needed
3 speed auto with O/D? 700R4? 200-4R?
There is a lot of info on this in quite a few threads on here. This is a very popular swap.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-30-2015, 11:19 AM   #3
hamjet
hamjet's Avatar
The 200-4r automatic transmission is the same length, output shaft is same spline so same driveshaft will work. you will have to remove the bellhousing mounted x-member and use a x-member at the transmission, either get a floor shifter or change column from 3 OTT to an auto. then of course trans. cooling lines to the radiator and TV cable and carb bracket for the cable. I did the swap and it dropped my rpms at 55 mph from 2500 to 1900, and thats not locking up the converter.. BTW, WELCOME!!
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
