Old 10-01-2015, 10:29 PM   #1
1972K20
1972K20's Avatar
Lift for a Cummins swap
I'm looking to do a 12V swap and want an adequate lift for such a heavy engine. This lift is for sale and is rated at "2 tons." Is this a good lift to do a 12v Cummins swap?
1972K20 is offline   Reply With Quote
Old 10-03-2015, 11:25 AM   #2
6BT 56
6BT 56's Avatar
Re: Lift for a Cummins swap
That's what I used . It was just acceptable . I made the kid ahead to the other end of the shop when any lifting was being done . Now a few times I lifted the eng trans and tc . That was dicey . Check my thread for a few " entertaining " lift pics .
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 10-03-2015, 01:07 PM   #3
1972K20
1972K20's Avatar
I just checked out your build, awesome truck and build!
I saw how you had your lift positioned. What size is your lift?
Old 10-04-2015, 11:23 AM   #4
brimc
brimc's Avatar
That's very similar to mine also. I used it without issues (although sometimes sketchy) to lift frame, axles, cab and box. Best and most used tool on my truck build.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 10-05-2015, 09:10 PM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Just becareful not to break those frotn wheels. I've done that and almost dumped an engine. Not fun there.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-05-2015, 11:30 PM   #6
1972K20
1972K20's Avatar
Thanks guys, I ended up getting the lift. It'll be a while before I get to test it.
