Carpe manana
![]() ![]() Join Date: Dec 2010
Educate me: Differences in BB exhaust manifolds for 71-72?
I've noticed two styles (borrowed pics below) of exhaust manifolds for 71-72 BB engines. One style has contiguous metal spanning adjacent ports (top pic), the other has no intervening metal between adjacent ports. Were both styles used on pickups? My 72 BB has the "contiguous" style and I believe these are original to the truck.
I'm looking at a spare set that is "discontinuous". The RH has part # 3989310 (looks correct for 402 or 454 passenger car) and the other looks like # 3914619 (couldn't locate application). Would these differing styles be interchangeable in a pickup? Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 10-08-2015 at 10:35 PM. Reason: Clarified point |
![]() Join Date: Apr 2011
Re: Educate me: Differences in BB exhaust manifolds for 71-72?
The top pair are the correct ones for for bb what I call the webbing on the bottom pair is gone not right near as I know I have a known original pair on my 72 if you need to know the numbers on them.
Moderator
![]() Join Date: May 2007
My 72 bb is original and has the style in the top picture. The bottom pictured manifold will work, but is not "correct" as far as I know.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Carpe manana
Thanks guys - I'll consider the set I'm looking at to be from a passenger car.
The exhaust on the C30 has a leak on the LH side that I believe is a bad gasket rather than a manifold crack but haven't had time to dig into it yet.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
![]() Join Date: Jun 2005
My 402 came out of a 71 motor home and has the top ste on the passenger side and the bottom style on the driver side. Must not be original?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
nothing runs hotter than a 70's motorhome so the odds of one cracking are very good
1970 short step c10 leaf spring 454 |
![]() Join Date: Jan 2012
Interesting! Do you suppose the factory left the webbing for truck engines and chopped it for passenger cars. I did see some casting #'s. are they completely different casting #'s?
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS ![]() |
#8 | ||
Carpe manana
So far looks as if the webbed examples were used on pickups and the non-webbed examples for passenger vehicles. "Heavy duty" style for pickups maybe?
Anybody getting casting #'s. I have a set off of a '79 3/4 ton buried in my shed. If I need to I'll dig'em out. No idea what they look like
Pete I took a look at my 69 396 truck exhaust manifolds today. The lh side was the same part number as the non webbed one you have pictured and the rh side had a different number also non webbed. I'm quite sure they are original to this truck. Not sure exactly when they changed over to webbed. I know the pics of the ones I sent you came off a 71 Sierra grande.
#11 | |
Carpe manana
![]() Join Date: Feb 2009
Just went through this though still somewhat a mystery: Per the 1979 parts book:
3994045 LH 333846 RH with A.I.R. this is the air pump for emission reduction: 343787 LH 353030 RH I also know at some point 3916178 to 3994046 to 333846. As for that A.I.R. baloney, forget about it, because the replacement parts can show the same part number for with and without A.I.R. ports. That's the case for at least the 353030, and possibly the 3994045, I can't remember. Fun, right? Additionally, I can only vouch for the 3994045 and 353030 on my truck that the castings do not match. The RH is like what you show on top of your first picture, the LH is like you show on the bottom of your first picture.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-13-2015 at 01:21 AM. |
#13 |
Know why the castings under the ports don't match LH vs RH?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-13-2015 at 01:35 AM. |
#14 | |
#15 |
Where/what is this "webbing" you guys are referring to?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#16 |
Carpe manana
The iron that bridges the bolt hole flanges between adjacent ports - pics illustrate the differences between "webbed" vs. "no-web"
#17 | |
Anyone know why the castings under the ports don't match LH vs RH? I believe this is consistent for many BBC vehicles, if not SBC as well.
