1998 K3500 srw rclb 4x4 ls427 swap
I bought the truck from a farmer about a month ago. it was abandoned in a field as rats had chewed the wires clear to the firewall. originally the farmer had a flatbed on it, but I am changing that to a longbed after the motor swap. here is how it looked when I found it.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's 1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's |
Re: 1998 K3500 srw rclb 4x4 ls427 swap
2 days later, I had new 33" tires on gm alloys.
then I found the poor farmers original actual problem....
the headlight coolant fluid was low...
but on a more serious note, I built this for it. ls427. gmpp new block, lunati sledgehammer forged stroker crankshaft, lunati forged h beam rods/arp 2000 rod bolts, probe forged longskirt pistons, lunati voodoo camshaft and springs, ported and polished 243 heads, ls6 aluminum intake, e85 injectors, big bore throttle body and maf, stainless steel headers, flowmasters... etc etc. conservatively... 490-500hp.
installed and now sporting my ac conversion.
ls return style fuel lines to gmt400 bracket...
I like how you did that fuel line bracket/conversion. Really interested to see where the rest of this project goes
1991 C1500 ECSB - 5.3 LS 4L80E 14bsf - Gone but not forgotten 1999 C2500 GMT-400 Crew Cab Short Bed - 6.0 LQ4 - 4L85E 2003 Denali XL - Wifeys Ride 2008 K2500HD Duramax Sierra Crew Cab Short Bed - Daily |
I do not like that fuel line set up at all. Compression fittings do not belong on cars.
I would recommend a double wall flare at the minimum. Or consider running new lines from the tank to the engine. They are probably rusty anyway. It should be a cool little truck when you get it all done. |
#9 | |
I'm in. what direction you going with the build?
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
its a fairly mild build. truck is staying stock looking. but new paint and it already has a nice interior. I want it all to function the way it is supposed to from the factory, so I will be putting time into the ls conversion for the gauges and ac and so on. just want a nice daily driver out of it. ls427 engine, 4l80e trans, bw4401 transfer case, 14bff rear axle, 9.25ifs front axle. front and rear e lockers, sitting on 33" mudders.
SHE IS ALIVE!!! LOL runs good. now to iron out any bugs in the systems.
#13 |
toying with a mild lift, like 2". and running a set of bfg 35" tires i have on this truck.
#14 |
![]() ![]() Join Date: Jul 2002
Truck looks like it will be a runner. Looking forward to future installments of your build.
#15 |
thank you for your kind words. she is a major project, but i think the hardest part is over. i hope lol.
#16 |
i actually have 3 of these trucks. i like the k3500 srw trucks. i have a 1994 k3500, this 1998 k3500, and i picked up a 1999 k3500 a few days ago. merry christmas to all.
#17 |
nothing new to report, other than i got sidelined off this one for a while. i had to build a truck for momma... if momma aint happy, nobodys happy lol. so likely on monday i will be back on this beast.
