Old 10-13-2015, 10:13 AM   #1
Aruba1
Video of my 1972 flatbed 5.3L
Posting it on this thread instead of the LS thread to tease some old schoolers .
I rebuilt the 2001 5.3L engine myself. Everything is std on the engine. Crank was polished. Block was honed. Heads were resurfaced and new valve seats installed. New cam, crank and rod bearings. New std oil pump. Std piston rings. The pushrod, cam, springs and lifters were re-used. I am running the old oil pressure and coolant temperature gauges. Next is to purchase a tach adapter to use the standard RPM gauge with the distributorless LS engine. For speedometer I will use a HUD electric unit. And hopefully soon I will have time to clean-up all the unnecessary wires in the engine compartment.
And it fits nicely on the 1997 NV4500 gearbox.
https://www.youtube.com/watch?v=CbZauKJEzoo
Aruba1 is offline   Reply With Quote
Old 10-13-2015, 12:43 PM   #2
flashed
Re: Video of my 1972 flatbed 5.3L
Got any pics to share ?
flashed is offline   Reply With Quote
Old 10-13-2015, 01:55 PM   #3
Aruba1
Pic1
Old 10-13-2015, 01:57 PM   #4
Aruba1
Old versus new(er)
Old 10-13-2015, 02:35 PM   #5
flashed
That is a sharp looking truck ,would love to see a side pic of the bed sometime .
Old 10-13-2015, 02:42 PM   #6
Aruba1
Thanks. Here is a before and after picture of the bed (has a hidden gooseneck hitch).
Old 10-13-2015, 02:47 PM   #7
Aruba1
This winter I will build a Heavy Duty ladder rack that will extend from the back up to the cowl area. It should be long enough so that the area over the bed can be moved or folded over the cab in case I need to load tall objects in the bed (i.e. fridge, furniture, gas tank, etc).
Old 10-13-2015, 02:48 PM   #8
flashed
Very nice ,Im looking for ideas to modify the ugly bed on my one ton if I ever get started on it.
Old 10-13-2015, 03:07 PM   #9
Aruba1
LOL, the flatbed in the picture I paid $150. I did all the cutting, welding, etc to make it look decent but at first it looked awful. I built this as a work truck, added a 1989 C3500 HD front suspension. Then I added tierod ends, balljoints, HD springs, HD shocks, etc. The rear is off the same C3500. Overall I am very very happy with the results. I could have done a better job with the paint. It's not bad but it won't win any shows (it's my first bodywork and paint job).
Old 10-13-2015, 03:18 PM   #10
hamjet
hamjet's Avatar
Very nice engine swap and great looking truck! BUT please don't pick on us old schoolers, we have feeling too..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 10-13-2015, 03:29 PM   #11
Aruba1
Wahahahaha.
Old 10-13-2015, 06:47 PM   #12
hugger6933
Turbo 350 in a one ton????? I have a 71 C30 and think of taking out grandma 4 to install a T400 if I can find one. Great looking one ton. Jim
hugger6933 is offline   Reply With Quote
Old 10-13-2015, 07:52 PM   #13
Aruba1
Actually it's a C20 converted to a C30. Wish I had a C30 to start with. This truck as gone through a lot of changes since I had. Actually I literally just finished installing some used updated door seals and I love them. Had to use a hammer to do some massaging and adjusting the doors a bit but I a happy with the results. Thursday I will install some LED lights in the cab and gauges.
Old 10-13-2015, 09:28 PM   #14
hugger6933
Shows me I didn't know the th350 came in the C20 truck either.
Old 10-13-2015, 09:29 PM   #15
hugger6933
but then again there is a lot more that I don't know. Jim
Old 10-13-2015, 09:46 PM   #16
engineer_gregh
engineer_gregh's Avatar
That is awesome!!
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 10-13-2015, 10:17 PM   #17
Aruba1
Ooops, I thought they came with the 4 speed, TH350 and TH400. The truck had a low hump tunnel and I had to cut it out and replace it with a high hump for the NV4500 to fit. I believe the TH400 came with the high hump so maybe the TH350 may have been am option?
