Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 10-20-2015, 08:43 AM   #1
Rich Gio
Help with bad windshield washer hoses inside firewall
I just inherited a "barn find" '88 Chevy C3500 with 29K original miles. It's immaculate but has a few issues from sitting so long.
The washer pump was bad, so I put in a new one. When I hit the switch I get fluid running out from under the body. I'm assuming a line is dry rotted or mouse eaten inside the firewall. How can I access these lines. Thru the cowl? How do I get it off? I don't see any screws.
Rich Gio is offline   Reply With Quote
Old 10-20-2015, 09:44 AM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: Help with bad windshield washer hoses inside firewall
You will go through the wiper cowl. Its fairly easy
Remove the wiper arms.
Remove the 2 outer cowl pieces(2 screws in each piece)
Remove the wiper cowl screws(I cant remember how many screws there are)
Remove the wiper cowl. You will have to disconnect the washer hose, the nozzles are attached to the wiper cowl.
You will now have access to all the hose. Its a good idea to lube the wiper linkage if your wipers squeak.
95 S_Trucker is offline   Reply With Quote
Old 10-20-2015, 11:14 AM   #3
54 jimmy
54 jimmy's Avatar
second 95 s trucker
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 10-20-2015, 02:09 PM   #4
Rich Gio
Thanks! I'll try that tonight.
Old 10-21-2015, 11:29 AM   #5
Rich Gio
Ok, so I am having issues getting the wiper arms off, but I was able to take out the cowl screws and get my paw down in there. I found a hose popped of at the "Y" fitting. I put the hose back on and tested. no flow. it seems the nozzles are plugged solid. Who sells replacement nozzles? All I'm finding are universal kits.
Old 10-21-2015, 11:55 AM   #6
95 S_Trucker
The dealer sells them, around $20 each
GM part # 22072439
Old 10-22-2015, 02:10 PM   #7
54 jimmy
54 jimmy's Avatar
if you can get them out. take a blow gun and blow them out backwards. probably full of dirt from being disconnected for so long.
Old 11-04-2015, 12:05 PM   #8
Rich Gio
I found new ones on Ebay 22$ a pair. Tried blowing / cleaning the old ones with no luck!
Old 11-07-2015, 07:20 PM   #9
Cape Codder
Cape Codder's Avatar
A wire pulled from a wire brush makes a great tool to clean wiper nozzles
Cape Codder is offline   Reply With Quote
Old 11-09-2015, 12:05 PM   #10
Rich Gio
I just replaced them. What a PITA that was!
Old 11-13-2015, 12:37 PM   #11
Chris95GT
Now that it's fixed, where's the pictures of this low mileage barn find?!? I wanna see!
1991 C1500 ECSB - 5.3 LS 4L80E 14bsf - Gone but not forgotten
1999 C2500 GMT-400 Crew Cab Short Bed - 6.0 LQ4 - 4L85E
2003 Denali XL - Wifeys Ride
2008 K2500HD Duramax Sierra Crew Cab Short Bed - Daily
Chris95GT is offline   Reply With Quote
Old 11-13-2015, 12:52 PM   #12
Rich Gio
Here she is...
