Old 10-26-2015, 05:41 PM   #1
OUbesto
OUbesto's Avatar
Question A/C vacuum actuator kick panel question
I am restoring the interior on my '70 C-10, 402 with factory A/C. The passenger side outside outside kick panel air vent appears to be controlled by a vacuum actuator versus the driver's side that is controlled manually by a pull-type knob.
First question...is this correct? I am assuming the passenger side vent is somehow controlled by the 4 season A/C system? Can anyone tell me how it actually works?
Thanks for any help anyone can provide.
OUbesto is offline   Reply With Quote
Old 10-26-2015, 05:59 PM   #2
haysonj
haysonj's Avatar
Re: A/C vacuum actuator kick panel question
There is a vacuum valve on the back of the controls and when you push the lever to inside air it closes the door on the passenger side. There was just a thread on this last week so you might be able to find it and I posted the vacuum hose routeing on it
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 10-26-2015, 06:02 PM   #3
OUbesto
OUbesto's Avatar
Thanks, I'll look for the previous thread.
1970 C-10 CST, LWB, 402/400, A/C
Old 10-26-2015, 06:48 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: A/C vacuum actuator kick panel question
Here is what your looking for.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-26-2015, 07:10 PM   #5
OUbesto
OUbesto's Avatar
Perfect, now I know how it works so next step will be to see if it's working properly. Thanks again.
a/c, vacuum actuator
