fuel
![]() Join Date: Jul 2003
relocated shock mounts???
ok im painting my frame and i was looking at the shock mounts, im going to get ece relocaters, do i need the ones i have now?? or should i cut them off before i paint?? this if for the rear of a 1972 shortbox, thanks
Yes. They bolt on in the stock location.
Watch out for your cornhole !
![]() Join Date: Jun 2003
To clarify, you will need to remove the riveted on stock upper mounts to replace with the ECE ones. So go ahead and remove the rivets.
#4 | |
SCOTI
I wasn't trying to fault your answer.
When I read your answer I thought it was not clear whether the shocks or shock relocators bolted in the stock location. Kevin
71 DELUX
Yep, cutting off the originals won't quite be enough to get the new ones in place, unless one means "cutting off" the head of the rivets to remove the old mount.
As long as this is being discussed, what sort od success/hassles have been encountered removed the stock mount with the bed in place? |
Do you need to replace the upper and lower mounts for the shock relocation? I thought you could just replace the lower ones.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Its actually a 4 piece kit, uppers and lowers
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
No harm, no foul
All of my Early Classic 4/6 drop, with shock relocators, shocks, super panhard bar, came in today. I can post pics of anything anybody wants to see. It's all laying in the floor.
Kevin
Well I'm waiting, where the pic's
69 swb stepside, rebuild and upgrade in progress |
#12 | |
67 is sold
#13 |
Allright, wait till tonight when I have more time
Kevin
