Old 11-23-2015, 02:02 PM   #1
gofastnut
gofastnut's Avatar
Fuel injector spider "clips?"
Hi guys and gals,
Just picked up a 96 C3500 4DR Long bed.
I'm replacing the old and bad spider with new/updated fuel injection spider.
That's the good news.
The bad news is that I plugged #1 injector into #3 hole.
Now I need a new white plastic tube/clip that goes over the end of the new injector, since they are a one time use.
HEEEELLLPPP!!
please
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 11-23-2015, 07:08 PM   #2
speedygonzales
speedygonzales's Avatar
Re: Fuel injector spider "clips?"
Just pull it out and move it. I've done it several times with no ill effect.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 11-26-2015, 07:23 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
Mmmmmm, Dorman parts? Their stuff is fine as long as it's not made with rubber, metal, or plastic
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 12-20-2015, 07:45 PM   #4
gofastnut
gofastnut's Avatar
Found an outfit back east that sells them, $6/ea. I couldn't get it to stay in when I put it in its CORRECT spot.
Problem solved!
Jeff
C-10 Club
fuel, injection, spider
