Old 11-28-2015, 06:42 PM   #1
Dino25Mumin
Dino25Mumin's Avatar
Painless Wiring my Big toe
alright so i have the wiring all setup and the rear section is not getting any power and the front left parking light is always getting constant power from the turn signal wire even with the ignition off. for the rear section i checking everything that i could think of. i pulled all the fuses tested them and their all good. i checked the grounds made sure it was all clean. Can anyone help?
Dino25Mumin is offline   Reply With Quote
Old 11-28-2015, 08:20 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Painless Wiring my ASS
Unhook the Alt, sounds like you may have a diode back feeding or a voltage reg problem. Other than tail lights the brakes run through the signal switch, signal switch and flasher relay. With a meter or test light see if you have power at brake switch,then check firewall connection,If no then the signal switch is giving you trouble. Make sure everything is good and grounded.
sneakysnake is offline   Reply With Quote
Old 11-28-2015, 09:43 PM   #3
mark 68
I've used two of their harnesses with no problems. They had excellent customer service a couple years ago.
mark 68 is offline   Reply With Quote
Old 11-28-2015, 10:45 PM   #4
Rod Run
Rod Run's Avatar
I've used them with excellent results in the past.
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 11-29-2015, 02:15 AM   #5
BossHogg69
motor exploder
BossHogg69's Avatar
I've got their kit on my '69, everything works fine - maybe call them up Monday and give them a chance to help you
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-29-2015, 03:50 AM   #6
toolboxchev
I am re doing my electrical from the info available on this site and recommendations along the way.
So far, I have learned a ton. Now if something fails I can diagnose it quicker, find other problems before they start, help and point others in the right direction.
I figure this site is for HOT RODDERS, guys who back yard something the right way. I have about 100 bucks in my electrical system and so far have some pretty white lights.
Now for that consumptive HEI...
toolboxchev is offline   Reply With Quote
painless, painless wiring, tail lights, wiring
