Old 12-22-2015, 01:52 PM   #1
6768chevylover
6768chevylover's Avatar
Suspension lifts
I was wondering if anyone has a cheap way of doing a suspension lift for our 69-72 blazers? Hope fully 2"-4" of lift if possible... Saw in a magazine for a suburban that an owner used parts from an f250 for lifting his rig but was curious if anyone has other ideas..
6768chevylover is offline   Reply With Quote
Old 12-22-2015, 03:06 PM   #2
cleszkie
cleszkie's Avatar
Re: Suspension lifts
Cheapest - body lift kit, or make your own.
Next Cheapest - Front lift springs, rear blocks.
Keep in mind that depending on the amount of lift you go for, you might need longer shocks, a raised steering arm toprevent bump steer, and extended front flexible brake lines. 4 inches of lift or less will not require a CV joint in the rear drive shaft, but anything greater than 4 inches definitely needs a CV joint to prevent driveline vibrations.
cleszkie is offline   Reply With Quote
Old 12-22-2015, 03:38 PM   #3
6768chevylover
Thanks. that would of been my next question about drive shafts. So front and rear I will be clear if I stay 4" and under?
